It is currently Thu Feb 20, 2020 10:25 pm
 Post subject: Profile Settings Problem
PostPosted: Sun Jan 12, 2014 6:28 am
I have attempted to change an entry in my profile but when I click to submit it says I must not spam these forums but I see no place to do that. Where is it located? I am using IE 8
Thanks............
KEEP AMERICA GREAT
PostPosted: Sun Jan 12, 2014 11:36 am
Thanks............
Your profile was set to have subsilver as the template.. With that template active the spam checkbox is missing. I have made the change to the motherboards_org template, so you should be able to make the change you need.. If you run into trouble still feel free to email me what you need changed..
Compaq-Fu Master
PostPosted: Mon Jan 13, 2014 9:36 am
OK, thank you for making the change for me............
KEEP AMERICA GREAT
