It is currently Tue Oct 23, 2018 6:49 pm
 Post subject: Have to keep logging in
PostPosted: Sat Dec 05, 2009 2:59 pm
I keep having to log in. It first started happening with Safari so I went back to using IE8 (8.0.6001.18828). Same thing. It doesn't happen all the time, but it does happen at the most inconvenient times, such as after typing up a post, having to log in after and losing the entire post I'd just written. Cookies are enabled for motherboards.org and I've tried clearing all the cookies, deleting the history, you know, the usual advice. Any ideas?
PostPosted: Sat Dec 05, 2009 5:36 pm
scanned for all malware etc stuff? No cookie filtering software installed?
tried another system at the same connection?
PostPosted: Sun Dec 06, 2009 3:24 pm
Could be a problem with the servers at your ISP location. They may be doing maintenance or testing, and IP links don't take much to be lost.
Does it happen only to one site, or several? Some ISP setups use a few 'doglegs' to complete a Web path.. and the longer or more interfaces, the more chance of a break. You could try a Ping Trace to see what the true path is.
PostPosted: Mon Dec 07, 2009 2:26 am
To be honest I don't know. I'll troll round a few of the old forums see what happens. No third party filtering, no malware detected (doesn't mean there isn't any, right?)
Pinging just times out, maybe a clue there.
This is my third attempt at posting.
PostPosted: Mon Dec 07, 2009 3:06 am
Okay, the problem is network related, nothing to do with the forums. Happened again while I was typing this. Did a trace ping, went no further than 172.16.199.250
Quote:
OrgName: Internet Assigned Numbers Authority
OrgID: IANA
Address: 4676 Admiralty Way, Suite 330
City: Marina del Rey
StateProv: CA
PostalCode: 90292-6695
Country: US
NetRange: 172.16.0.0 - 172.31.255.255
CIDR: 172.16.0.0/12
NetName: IANA-BBLK-RESERVED
NetHandle: NET-172-16-0-0-1
Parent: NET-172-0-0-0-0
NetType: IANA Special Use
NameServer: BLACKHOLE-1.IANA.ORG
NameServer: BLACKHOLE-2.IANA.ORG
Comment: This block is reserved for special purposes.
Comment: Please see RFC 1918 for additional information.
Comment: http://www.arin.net/reference/rfc/rfc1918.txt
RegDate: 1994-03-15
Updated: 2007-11-27
OrgAbuseHandle: IANA-IP-ARIN
OrgAbuseName: Internet Corporation for Assigned Names and Number
OrgAbusePhone: +1-310-301-5820
OrgAbuseEmail:
OrgTechHandle: IANA-IP-ARIN
OrgTechName: Internet Corporation for Assigned Names and Number
OrgTechPhone: +1-310-301-5820
OrgTechEmail:
# ARIN WHOIS database, last updated 2009-12-06 20:00
