Avatar problem:
Avatar problem:
Postby Karlsweldt » Sun Apr 26, 2009 3:15 pm
Not a problem with Motherboards.org, but with www.uploadit.org not being responsive. Don't know the reason.
That is why my Avatar does not show in postings. Anyone else that has a link to uploadit.org may have a problem.
Until uploadit.org is back on line, I have submitted my Avatar to Motherboards.org for use.
Edit: 04/29th..
Looks like www.uploadit.org/ is back on line. Hope it was nothing serious.
