no borders.....
no borders.....
Postby sloopdog 1 » Fri Apr 10, 2009 5:41 am
between posts and replies.happens all the time, all the forums.has been doing so for quite some time.
subforums resized to 1/2 of monitor screen.
No keyboard detected-Press any key to continue.
sloopdog 1
Postby Karlsweldt » Fri Apr 10, 2009 3:19 pm
I use Firefox, and the latest versions have an auto screen-size feature. Whatever the text line length, that is the screen width.
No problem with IE, but FF is more secure and faster.
Postby sloopdog 1 » Sat Apr 11, 2009 6:59 am
I use FF also.
sloopdog 1
