logging into the board
Postby cw4cam » Wed Oct 01, 2008 3:26 pm
I'm just wondering why I have to log in every time I visit. I have checked the box "keep me logged in" or something like that. It could be something related to FF 3. something. Its not a big deal, just unhandy. The little icons to the left of the page used to be bold orange if I had not viewed it. They are now just blue. ???
:oops: Fixed by reading on down to Karls fixes for other log-in probs.
"A pessimist sees a problem with an opportunity. an optimist sees an opportunity with a problem."
Winston Churchill
Civilization is invaded by barbarians every generation. (author unknown)
cw4cam
Postby evasive » Thu Oct 02, 2008 12:36 am
what was the problem after all, you could help others with similar issues...
