loggin in
loggin in
Postby whiteboy » Fri Feb 22, 2008 10:02 am
OK since I install vista on my new system I have to log into thte site everytime I open the page. If I close the browser or if I even goto another site in that window/tab; when i come back I have to sign back in. What is going on? and is it a vista thing?
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
whiteboy
Postby Ripshod » Fri Feb 22, 2008 10:47 am
Not a forum problem. I have the same thing in IE or firefox under vista.
Ripshod
Postby whiteboy » Fri Feb 22, 2008 11:43 am
yeah must be a vista issue...anyone know how to fix
4 gigs ram
whiteboy
Postby hunter1801 » Fri Feb 22, 2008 12:35 pm
http://www.motherboards.org/forums/view ... p?t=100628
Sort of the same problems that go along with this. Not just a Vista problem though.
hunter1801
Postby whiteboy » Fri Feb 22, 2008 12:42 pm
yeah i tried that thread... had no problems on my old system. built my new one and install vista and now i can't stay logged in.
4 gigs ram
whiteboy
Postby Karlsweldt » Fri Feb 22, 2008 5:45 pm
A new OS using old "cookies". And perhaps two Firewalls in operation?
If using the built-in OS Firewall, disable or uninstall the other (if applicable).
Manually delete any cookies in existence from previous sessions.. and remove those URL inks from the "faves". Create an entirely new URL link and set your Firewall to "fully trust" those sites you know are secure. If set to "filter", possible a connection break may be simulated as the Firewall process scrutinizes data incoming for the prevention of a port attack.
Postby whiteboy » Fri Feb 22, 2008 7:56 pm
just the basic vista firewall for now. Already tried delteing cookies and not using any saved links. it does anytime i go to the site even if i was just there 10 minutes before, move away from it in the same window, and when i come back have to sign in again.
4 gigs ram
whiteboy
