Problem on my end?
Problem on my end?
Postby MrCraigCraig » Thu Dec 27, 2007 3:12 pm
Dear Forum Members,
For the past few days I've not been able to access this site via MS Internet Explorer (Windows XP Home Edition).
I can access other websites ( like www.amd.com for example ).
Tonight I'm using a Puppy Linux Live CD equipped with SeaMonkey to reach www.motherboards.org and these forums.
What could be causing my Internet Explorer access attempts to fail?
Does this site have quirks or features that would run afoul of internet security software?
Sincerely,
MrCraigCraig
MrCraigCraig
Postby evasive » Thu Dec 27, 2007 4:33 pm
ipconfig /flushdns
and clear your temporary internet files
Postby MrCraigCraig » Sat Dec 29, 2007 5:06 am
Thanks.
MrCraigCraig
