It is currently Fri Jul 19, 2019 2:54 am
Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
PostPosted: Sun Dec 30, 2007 9:08 am
The key word is "certificate" which indicates the site's trustworthiness, having posted its intent in honesty and user-friendly manners, and is registered with various other organizations. If the "certificate" has expired or is not currently distributed, then the Firewall program will block access by default.
Quoted from Windows "Help".. Certificates:
Quote:
A collection of data used for authentication and secure exchange of information on nonsecured networks, such as the Internet. A certificate securely binds a public encryption key to the entity that holds the corresponding private encryption key. Certificates are digitally signed by the issuing certification authority and can be managed for a user, a computer, or a service. The most widely accepted format for certificates is defined by the ITU-T X.509 international standard.
See also certification authority; ITU-T; private key; public key; service.
From Verisign:
From a Google search:
PostPosted: Sun Dec 30, 2007 10:30 am
Thanks Karl. That's probably what I was overlooking.
PostPosted: Sun Feb 03, 2008 6:46 pm
Alright, I found a work-around for those of you (including me) who are still having login issues:
Problem:
Logging in through the main page doesn't always work. If you try to log in, it will sometimes take you back to the forum page, but you are still not logged in. Retrying sometimes works, but then all the new post markers are cleared, so you have no idea what threads have new posts.
Solution:
I have been testing this over the past 2-3 weeks, and it ALWAYS works (100% of the time) for me. Instead of logging in through the main page, click ANY forum (General, Tech Support, Gaming, ect). Then click on "New Topic" as if you wanted to create a new thread. This will require you to log in, so when the login screen appears, log in as normal. Then just click "forums" at the top of the page again, to return to the main forum page. This logs you in 100% of the time without any issues.
- So it appears that logging in from the main page is faulty, yet doing the work-around I mentions lets you log in fine. I don't know why that is, but thats the only way I have found to log in properly.
NOTE: It still logs me off every time I exit out of the website. So every time I come back, I have to log back in since it doesn't save. At least I don't have to keep trying to log in, then not be able to see new posts.
PostPosted: Sun Feb 03, 2008 11:47 pm
I found another pseudo-solution which seems to be working. Since the site works with the Internet Explorer engine, it occurred to me - using IETabs! For those who don't know, there's an extension for Firefox called IETabs which allows you to open IE-only websites within Firefox; what it does is opens them in Firefox but renders the page using IE's engine (which leads to slightly higher load time for the first page because it has to switch IE on...) - and it has filters, so I have set it to automatically load *.motherboards.org/* in an IE tab, so I don't even have to think about doing it. Works 100% and is a great way past the problem, as the IE part seems to (mostly) remember my details.
