It is currently Mon Jul 22, 2019 3:01 pm
Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
PostPosted: Wed Dec 05, 2007 3:58 pm
PM/Email olle. You might want to PM doc too. Us mods don't really have any power to fix this, many of us including me had your same problem. Although it seems like for most people it is working fine.
Join team 33258 today!!
PostPosted: Wed Dec 05, 2007 6:09 pm
hunter1801 wrote:
I never stay logged in. When I do log in, it doesn't work the first time. Have to log in twice for it to work, and when I get logged in, all the new post markers are reset.
Clear your cookies? That's what finally fixed it for me. Also, make sure you're running the latest version.
RIAA vs The People
PostPosted: Thu Dec 06, 2007 11:01 am
Yes, I did all that. Ive cleared cookies, used CCleaner, cleared temp/cache, no firewall, ect. Only happens for this site
PostPosted: Thu Dec 06, 2007 12:03 pm
Have you (a) if you are using a "Favourite" link have you deleted and re-added it from new? Or (b) as a last resort, you could try reinstalling your browser.
PostPosted: Thu Dec 06, 2007 1:11 pm
Im not using a bookmark or anything. Reinstalling FF isn't a big deal so I will try that. I've patched it multiple times, so I figured that would solve the problem if anything.
PostPosted: Thu Dec 06, 2007 2:13 pm
The 'cookies' which are URL links in FF are found from the top tool bar, "Bookmarks/Organize Bookmarks". You can spread the page over the entire screen, and select which URL links you wish to delete or move about or rename. Just delete the URL link for the site you have problems with, and revisit.. for a new 'cookie'. Don't forget to check the "properties" of the link for the URL address to copy and paste in the browser bar to revisit!
Pull down the FF "Help" window then "Help Contents", and drop down to "Managing Cookies" for an explanation of how to work them.
And.. you may have to check the Firewall program(s) to ensure the site is 'fully trusted'.
PostPosted: Fri Dec 28, 2007 9:37 pm
Just an update. Built a new rig, installed FF version 2.0.0.11 and no problems with the site anymore! Heh, guess all it takes is a fresh install of Windows (joking).
Antec Nine Hundred
Intel C2D E6750 @ 3.6 Ghz
Gigabyte P35 DS3L
Mushkin Redlines 2 x2GB kit
EVGA GTX 260 Core 216 896 MB
WD 250 GB SATA2
Seagate 160 GB SATA
WD 500 GB SATA2
Thermalright Ultra 120 Extreme
PC P&C Silencer 750W
Windows XP SP3
PostPosted: Sat Dec 29, 2007 2:08 pm
Maybe I'll be able to visit the forum normally once I build a new computer sometimes in the next 2 years :roll:
PostPosted: Sun Dec 30, 2007 8:45 am
As a side note, shouldn't this site, www.motherboards.org and its' components, contain content that DOES NOT TRIGGER alerts, warnings and preventive measures from Web-browsing, Firewall, and/or Anti-Virus software??!!??
PostPosted: Sun Dec 30, 2007 8:49 am
It's not just FireFox that gets tripped up by this website.
There have been problems with accessing and staying logged on to this site by various forum members, using various web-browsers, in the past.
This happened to me recently.
http://www.motherboards.org/forums/viewtopic.php?t=103668
