It is currently Fri Jan 18, 2019 7:09 pm
Post new topic Reply to topic  [ 74 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
PostPosted: Sun Aug 05, 2007 1:32 pm
it appears in fixing the code for loggin in with IE the other browsers no longer work. Evan!!!!!!!!
PostPosted: Sun Aug 05, 2007 4:37 pm
Yep. I can't log in with Firefox either. Had to fire up IE for the first time in months to be able to log in and post. :(
Antec Nine Hundred
Intel C2D E6750 @ 3.6 Ghz
Gigabyte P35 DS3L
Mushkin Redlines 2 x2GB kit
EVGA GTX 260 Core 216 896 MB
WD 250 GB SATA2
Seagate 160 GB SATA
WD 500 GB SATA2
Thermalright Ultra 120 Extreme
PC P&C Silencer 750W
Windows XP SP3
PostPosted: Sun Aug 05, 2007 9:23 pm
Same for me. :( In SeaMonkey (Mozilla) I can't login, but in IE I'm already logged in.
:-| Hopefully this problem will be fixed soon.
PostPosted: Mon Aug 06, 2007 8:07 am
Hope this gets fixed soon. I hate IE, love firefox :(
"A pessimist sees a problem with an opportunity. an optimist sees an opportunity with a problem."
Winston Churchill
Civilization is invaded by barbarians every generation. (author unknown)
PostPosted: Mon Aug 06, 2007 8:38 am
I just killed my cookies only from my Private Data in Firefox and now I can login again. So if anybody still has issues, try that.
PostPosted: Mon Aug 06, 2007 10:20 am
Hey evasive got the trick. It works now for me on firefox after deleting cookies.
GIGABYTE GA-M57SLi S4
AMD Athlon 64 X2 6000+
6 gigs o' Ocz reaper pc6400 (2x1gb 2x2gb)
2x Nvidia 8800GT 512MB Fact. OC'ed
3xWD 500Gb 16mb cache sata2
MX518
G15
IceMat Siberia Headset
650 W PSU
Gigabyte 3D Mars (case)
Acer AL2223W (monitor)
Windows Vista 64-Bit SP1
PostPosted: Mon Aug 06, 2007 11:11 am
okay it only works temporarily. I only works for a couple minutes and you have to delete cookies agian.
MX518
G15
650 W PSU
PostPosted: Mon Aug 06, 2007 1:04 pm
I suspect code still not 100%. Seems the cookies are invalidated too soon as a measure to clean up faulty cookies perhaps. We'll see. For now we'll have to hang in here...
PostPosted: Tue Aug 07, 2007 1:15 am
Finally able to login, only after clearing data. I was worried for a while.
Join team 33258 today!!
PostPosted: Tue Aug 07, 2007 4:45 am
For some reason it works fine at home on firefox, but not at work. Both are the latest patches. At work I have to delete the motherboards.org cookie folder before logging in.. At home I'm using the same cookies from a month ago.
