Graphiccard basics
Graphiccard basics
Postby Wolfgang Krebl » Fri May 31, 2002 3:17 am
Today I´ve a very basic question about graphiccards.
Is there any way to determine how much video memory I need for a specific resolution (for example: Whats the higest possible resolution for a videocard with 1MB memory)?
Thanks for your help
Best wishes
Wolfgang
Wolfgang Krebl
Postby asassin' » Fri May 31, 2002 9:17 am
horizontal pixels X vertical pixels X color depth; i.e.
800 X 600 X 2 bytes = 960,000 or
1024 X 768 X 1
asassin'
Postby Hardware Junkie » Fri May 31, 2002 9:43 am
I think you should be worried about quality at a certain resolution. Most people are 800X600 or 1024X768 these days. Anything higher then an 8MB card will do that just fine at a reasonable resolution.
When purchasing a card, just do a bit of research into it.
Postby Wolfgang Krebl » Sat Jun 01, 2002 12:31 am
Thanks for your fast replies! :lol:
My problem is the following: I sell a Compaq Presario with an Diamond A200 AGP 8MB graphiccard, and I´d like to know which resolutions are possible with this graphiccard.
Is such a card capeable of delivering a fine picture at a resolution at 1280x1024?
If I got asassin´ right a 8MB card should be capeable of an resolution of 1600x1200x16bit. (1600x1200x4byte=7.680.000)
But is the quality of such an resolution acceptable?
Anyhow -thanks again for your help
Best wishes
Wolfgang
Wolfgang Krebl
Postby timmib » Sat Jun 01, 2002 1:36 am
Greetings,
Part of the quality question has to do with refresh rates supported. Might check the card's spec's.
Be well,
Tim
timmib
Postby evasive » Sat Jun 01, 2002 2:11 am
Oh and make sure the monitor supports those resolutions/color-depths/refresh rates...
Postby Hardware Junkie » Sat Jun 01, 2002 12:31 pm
Here are the specs for the video card:
S3 128-bit 2D, 3D and video engine – Savage4 Pro
AGP 2X (compatible with AGP 1X systems)
S3TC® texture compression for superior 3D image quality
Fast, full-color 2D performance with resolution support up to 1600x1200
8MB of fast SDRAM memory
Hardware-accelerated DVD for fast and smooth DVD (MPEG-2)
Cinema-quality display of MPEG-1 titles
Complete Direct3D® and OpenGL® ICD support
Microsoft WHQL certified for compatibility
Optimized drivers for full compatibility with Windows® 95/98, Windows NT® 4.0 and Windows 2000 (when available)
Postby andrey » Sat Jun 01, 2002 1:57 pm
its all down to the monitor for you, as to how high it can go. the video card can support up to 1600x1200 as quoted above.
________
medical cannabis
andrey
Postby Hardware Junkie » Sat Jun 01, 2002 2:00 pm
When looking into an old monitor, get the model and look it up on the net. If you can find information, see what the specs are. If you can't find anything, then its most likely a POS and not worth it. :?
Postby Wolfgang Krebl » Sat Jun 01, 2002 10:27 pm
All Right - thanks again for all your help and devotion to my problem. The monitor is a Samsung Syncmaster 19", and he is capeable of all resolutions
the card can provide.
So I got the deal made perfect and my customer is satisfied about her new computer. :D
Again - thanks a lot for all your help
Best wishes
Wolfgang
Wolfgang Krebl
Return to General
