OverClocking VideoCards
Postby spraks » Thu May 30, 2002 12:59 pm
well i plan to buy a GAINWARD/CARDEXPERT GEFORCE2 Ti450 and ppl say that they can overcloak the video card even higher as high as a geforce 3... any1 noe how to do this before i buy it?
"Don't Drink And Drive At The Same Time, U Might Spill"
Postby somedude » Thu May 30, 2002 1:22 pm
Dude, the only way I know is after you buy it. :wink:
Usually, overclocking a card is achieved by increasing the bus speed, which increases the PCI and AGP speed. That means you'll be overclocking the cpu as well. Most mobos and/or cpu's don't like overclocking, so it depends a lot on your mobo and cpu.
"I can't buy that. Only management guys with big salaries like me can afford that...
Guys like me! I'm a guy like me!"
Homer Simpson :)
Postby Bulldog » Fri May 31, 2002 5:50 am
You go to asite and download either coolbits, NVtweak or Riva Tuner, and that allows you to use non WHQL drivers and sets up a overclocking utility,that allows for memory and core adjustments depending on how serious you are at OC the easiest 1 is coolbits,then NV,then Riva tuner you can get more out of card with lasr 2 but settings take some reading to really tweak to prefectionhttp://www.guru3d.com has all your answers
Return to General
