AMD MP vs XP
AMD MP vs XP
Postby spraks » Wed May 29, 2002 5:53 pm
ok first off i wanna noe wat a AMD MP is... is it really good because they cost more then the XP 2100+... which do u ppl recommend in a asus av7333??
"Don't Drink And Drive At The Same Time, U Might Spill"
spraks
Postby Hardware Junkie » Wed May 29, 2002 6:10 pm
The Asus A7V333 Motherboard is quite a good board.
The Athlon MP processor is used for multiprocessing on a Dual board. It does not have any advantage in single mode.
Postby Bulldog » Fri May 31, 2002 5:54 am
I disagree, the MP has been proven to use a higher grade of silcon, and is factory unlocked if your a serious O/C you will have a better chance of hitting higher FSB with MP...IMHO...I did some research on this testing 3 xp 1800 retails vs 3 MP 1800 retail and every one of MP's clocked higher than highest clocking XP
Bulldog
Postby Aibohphobia » Fri May 31, 2002 5:18 pm
wow neat. do MP's work on the same mobos as XP's or do they require mp's? and where is this site?
Goddam mad dog!
Aibohphobia
Postby Hardware Junkie » Fri May 31, 2002 5:30 pm
Actually that is true. They also handle rising heat a bit better. But if your looking at the advantage of one processor over the other in a desktop system, there is not much difference.
Postby spraks » Fri May 31, 2002 5:40 pm
so which one? Xp 2000+ or Mp 1800+? cause they are the same price
spraks
Postby Hardware Junkie » Fri May 31, 2002 5:47 pm
Well when you put it like that I would go with the XP 2000+ if you do not plan on overclocking.
But if it was an XP 1800+ VS an MP 1800+, then the MP would be the chip to go for.
Postby datektrader21 » Fri May 31, 2002 5:53 pm
So when is AMD releasing mps with the new thoroughbred core? And what about tang where can i find some tang? :P
datektrader21
Postby Hardware Junkie » Fri May 31, 2002 5:56 pm
I don't know if AMD is planning on releasing MP versions of the new core. The only reason the MP was released was because the XP could not handle SMP (atleast not well).
New new core might be able to do SMP aswell.
Return to General
Users browsing this forum: Istellabot [Crawler] and 2 guests
