It is currently Tue Oct 16, 2018 12:02 am
 Post subject: Asus A8n Premium help
PostPosted: Wed Nov 09, 2005 5:44 pm
I have $2200 and tomorrow I will go to tigerdirect store and buy all the components for my new rig, I was wondering if this will be compatable, because I have heard the A8N premium is a tough motherboard for compatability. NOTE: I am not going to overclock at all, I just want to run stock high quality parts. Will this work??
CPU - AMD X2 4800+
GPU - BFG 7800 GTX OC
PSU - Ultra X-connect 500w
Ram - OCZ Titanium dual channell 2048 ddr400 pc3200
- do I have to run dual channell - can I run just 1 1024 stick right now?? or do I have to have two?
HDD - Western digital 160 gig IDE (soon to be raptor 74gig)
DVD - Plextor 716SA
Watercooled - Thermaltake big water
Any suggestions? Again, since this is a dual core 4800 I don't see the need to overclock, I want stability and very high quality parts. Thank you for the input in advance, I appreciate it!!
PostPosted: Wed Nov 09, 2005 5:57 pm
CPU - AMD X2 4800+
DVD - Plextor 716SA
Everything is fine except for the power supply. If you want the highest quality parts, dump the X-connect and go for an OCZ or an Antec PSU. Ultra X-connect, although incredibly pretty have some issues with their connectors and the Ultra X-connects motherboard connector is only 20 pin and doesn't have sepperate power for SLI. The A8n Premium motherboard is 24 pin.
Thats gonna be one awsome computer.
PostPosted: Wed Nov 09, 2005 6:22 pm
I was actually using the X-connect on my P4 3.4 ghz LGA 775 processor and board, -- I bought a cord separatly in order to hook it up to the 24 pin, so I should have it, right?? And I beleive I have the SLI connector as well?
PostPosted: Wed Nov 09, 2005 6:23 pm
also you might want to save your money and not buy a raptor its not worth the money some of the newer drives that hold more are almost as fast and alot cheaper
Join team 33258 today!!
PostPosted: Wed Nov 09, 2005 6:29 pm
I have heard some horror stories about using SATA drives - such as the plextor 716SA - will this be a problem? Also, I have built computers before (3.4 ghz P4, Intel 915pbl board, etc) but is there anything I need to keep in mind when booting and building this PC? Does this motherboard need special settings in the BIOS? or can I just use the stock BIOS - Again, I do not want to overclock, I want stability w/ some high quality parts. Thank you for your patience with my noob questions!
PostPosted: Thu Nov 10, 2005 7:42 am
A 1 Gb RAM module would give very good results, but there would be a slight bandwidth improvement if going the dual-channel mode, if your mobo accepts it. You may experience up to 10% increase in bandwidth speed, over a single module. Unless you have need for greater than 1 Gb of memory, stick with the "optimized" limit of 1 Gb. Two 512 Mb modules would fulfill the dual-channel mode, and you will still have 1 Gb total. The memory bus is addressed separately for each module, in dual-channel.
Wit dual-channel setup, ensure the memory you obtain is "matched" for best performance.
Reference.
Suggestions.
Tech Speak.
