using old pci graphics card with new mb
Postby Robpeteuk » Tue May 28, 2002 5:52 am
Is there any problem with using an old 2mb pci graphics card with a new mb with a 4xagp as I do not need fast graphics at the moment though I may upgrade in the future. I presume not though I wanted to check. Thanks Rob
Robpeteuk
Postby Toby B. » Tue May 28, 2002 7:19 am
There should be no problem at all using a PCI graphics card in a mobo that supports AGP cards. Read your manual closely!!! you may need to disable the AGP in order for the PCI card to work properly.
Hope this helps
Toby
Toby B.
Return to General
