Other than $150, what's diff between 512mb and 1028mb ram?
Postby Flyin » Mon May 27, 2002 2:31 am
I won't be doing video editing, I just don't feel technologies up to snuff when converting vhs to vcd/dvd. What kind of performance difference is there between this system with 1 stick of 512mb of Samsung PC 2700 ddr ram and 2 sticks?
(I'm gonna list every component incase each makes a difference)
Asus VIA A7V KT333 mobo
AMD Athlon XP 1900
ATI Radeon 8500 128mb DDR(retail)
Maxtor 80GB 7200rpm Quiet Drive
Lite On 40x12x48 CD-RW
Hercules Gaming Theater XP 6.1
Klipsch ProMedia 5.1 THX Audio System
Thanks for reading!
Flyin
Postby Tolemac » Mon May 27, 2002 2:39 am
The difference is that you will have more than enough RAM no matter what you're doing. 512Mb is fine for almost anything except heavy graphics apps that use a lot of memory. Then you need to go with 1 or 2Gig of memory.
Tolemac
Postby Flyin » Mon May 27, 2002 3:38 am
Looks like I have an extra $150 to play with then! I'd surely know by now if I was planning on using any heavy graphics apps. I mean, photosuite and what have you won't need a gig of ram will it?
Flyin
Postby Tolemac » Tue May 28, 2002 1:51 am
Not necessarily. What I mean is more along the lines of Cad/Cam work and serious video/photo editing software. 512Mb of RAM should be fine for Photoshop and Paintshop and the like. 8)
Tolemac
Return to General
Users browsing this forum: YandexBot [Bot] and 2 guests
