It is currently Sun Sep 23, 2018 11:47 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri May 31, 2002 11:35 am
DUDE!!!!
HOLD ON!
Did the settings I told you to change stick? Did you then change the multiplier to 13x?
Does it say 1300MHz now?
Don't leave me hangin' here, I need CLOSURE!!!
"I can't buy that. Only management guys with big salaries like me can afford that...
Guys like me! I'm a guy like me!"
Homer Simpson :)
PostPosted: Fri May 31, 2002 11:39 am
Ok this is what happened. You suggested I take out the pc100 and only keep the pc133, so I did. I then went to the bios screen and this is what it said:
CPU speed: manual
CPU freq multiple: 5.0x
CPU/PCI freq: 100/33
CPU/mem freq ratio: 3:4
then I rebooted (saved changes) and then went back in, and made the following changes
CPU speed: manual
CPU freq multiple: 13.0x
then I rebooted again (saved changes) and this is what I saw on screen
CPU speed: manual
so I went to cpu speed, pressed enter, a little window popped up with 3 options, manual/500MHz/667MHz
then I rebooted again, and set windows to install again while I wrote that post
Vogue
I bet I can run faster scared, than you can mad!
PostPosted: Fri May 31, 2002 11:48 am
Hey check it out the install went through...It got through the first copy session, then rebooted, got through the second copy session, rebooted, now its at a beautiful light blue screen with some writing on it...I'm gonna go see what it says, but this is as far as I've gotten today with the xp install...
Vogue
PostPosted: Fri May 31, 2002 12:25 pm
Vogue Dude,
When you turn on the computer it usually tells you what kind of cpu and how fast it is. Does yours say now: Duron at 1300MHz?
It should, because that's what it's set at.
By the lloks of it, it runs stable. It should also be fast.
IS IT??? :?: :?: :?: :?:
Homer Simpson :)
PostPosted: Fri May 31, 2002 12:37 pm
Yeah yeah it says that. Also, it says that when you go to control panel --> system...which means I INSTALLED XP!!!!! OH GOD I'M HAPPY! I mean yeah its gonna be a while to configure that friggin network again before I have internet, however I'm willing to pay the price, at least its working. Thanks a lot eh, I appreciate it!
Vogue
PostPosted: Fri May 31, 2002 12:51 pm
U DA MAN!!!
8) 8) 8)
Homer Simpson :)
PostPosted: Fri May 31, 2002 1:51 pm
IT WORKS! IT WORKS!! AAAHAHAHAHAH IT WORKS!!! WHO DA MAN!? WHO...DA...MAAAAANNNNN!?!!!! YEEESSSSS!!! CAN'T TOUCH THIS TAAAAA-NA-NA-NANA NA-NANA NA-NANA!!!
Thanks to all of you, especially somedude for having the patience to sit a pure n00b through it, thanks bud!
Vogue
PostPosted: Fri May 31, 2002 2:43 pm
No problem Dude. Glad I could help.
Homer Simpson :)
