It is currently Fri Sep 21, 2018 10:04 pm
 Post subject: XP and dial up
PostPosted: Thu May 23, 2002 10:29 am
I was wondering if anyone has had the same problem with xp and dial up. Every time i disconnect, my system hangs and sometimes freezes. I can actually connect faster with XP than with ME but once i need to disconnect, it freezes my computer.
PostPosted: Thu May 23, 2002 10:35 am
Check to see if there are updated drivers for your modem that are XP compatible. 8)
The Gift of Healing
Conscious Energy Meditation
PostPosted: Thu May 23, 2002 11:08 am
For my curiousity, do you use Microsoft messanger and .net strategy software running in the background? Also were you in secured connection and did not log out when you disconnect?
PostPosted: Thu May 23, 2002 12:11 pm
no to both questions
PostPosted: Fri May 24, 2002 11:47 pm
which modem do you have? it is a winmodem?
Goddam mad dog!
Users browsing this forum: Bing [Bot] and 4 guests
