It is currently Sat Sep 22, 2018 7:08 am
 Post subject: Soyo P4S Dead Board??
PostPosted: Thu May 23, 2002 5:58 am
I just installed a new Soyo P4S and powered on. I get one long beep and two short beeps, no video. I have switched AGP video cards around and have verified that the cards are good. The board is from Newegg.
This is the second time this has happened to me. Last month I had the same thing happen with a Soyo P4S that I installed in diffrent box. It was from Fry's and they exchanged it and the new one worked fine.
Am I just one lucky guy or is there something else going on?
Video card is ATI Radeon 7500.
PostPosted: Thu May 23, 2002 8:53 am
Welcome to the Mother Board!
You want to make very sure that the video card is fully seated in it's slot. Even a little of the card can be out and it will give this beep code. Check all of your connections while you're at it. Some boards are more particular than others which is a good thing, but can be frustrating if everything is not installed perfectly. 8)
The Gift of Healing
Conscious Energy Meditation
 Post subject: Thanks
PostPosted: Fri May 24, 2002 10:45 am
I don't think it is a card seating problem. The AGP slot does require much insertion force. I've requested a RMA from newegg. I am not usually so lucky as to get one of only 1 bad board per 100(?) twice.
Since the odds are probably over 10,000 to one I was thinking this might be something else, more common, like ingorance.
 Post subject: OPPS!
PostPosted: Fri May 24, 2002 10:46 am
I meant to say that the card does NOT require much insertion force.
