Looking for Network Backup software Win98
Postby Loser » Thu May 23, 2002 5:41 am
:D
I am running a 5 station star win98 network & need a good backup software to backup files from one hard drive to a 2nd drive on a different workstation. Any suggestions. - Looking for reliability, low price <$200.00, ease of use, and ability to backup without backup tape drives or traditional backup devices.
Thanks,
Ken
Loser
Postby Need For Speed » Thu May 23, 2002 5:55 am
I don't know if this is the answer or not, but Norton Ghost maybe????
Need For Speed
Postby Wyrm73 » Fri May 24, 2002 7:42 pm
How does free sound? Use the backup utility included with Windows. If it is not on your computer, you can add it from the add/remove programs icon in the control panel. It is under the windows setup tab. I know it is not the best, but it works and it fits your budget. You can just point the destination of the backup file to a hard drive on another computer on the network.
Wyrm73
Return to General
