It is currently Thu Jul 18, 2019 9:58 am
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Sat Aug 21, 2004 6:31 pm
Most, if not all case fans run on the +12 volt rail.
PostPosted: Sun Aug 22, 2004 12:30 am
Unless they are 5V fans :P
PostPosted: Sun Aug 22, 2004 1:02 am
Hmm fans...
Cpu, case and chipset fans 99.001% (I made that number up, but its realistic! :P ) of the time are +12v.
What you should know about having a small or cheap power supply is that when a system powers on those motors draw 3 times more than they actually use.
In fact anything with a motor has a huge power spike at initial startup, although it doesnt take much to move a fan they do draw a huge amount of amps at boot. Once a fan or motor is spinning the amps drop immensly.
But overall dont read too much into any of this.
Most power good supplies and even some cheap ones can power more than they are rated for.
A good company can sell a power supply that can exceed the rated draw and still clean up the power from the wall socket, a poor power supply is just over rated and can not meet its draw ratings with out burning up and/or it does not give clean even power.
The circuitry and parts used in a power supply makes all the difference IMO.
I live in an old house in florida where nasty storms hit all of the time and the power always fluctuates, this has a direct bearing on the power supply, good ones will keep the power even, poor ones will jump up and down.
again I rant, sorry
PostPosted: Sun Aug 22, 2004 1:14 am
kltsin wrote:
Hmm fans...
again I rant, sorry
your correct , in what you say. an item in our pc which is often over looked
PostPosted: Sun Aug 22, 2004 1:31 am
TY coppershirt...
I did leave out the many other details but thats why I wrote a web page about it.
Most systems would be fine with a good 325 watt power supply, its the graphics cards that are tricky since they can draw a huge amount of power or very little depending on the card in question.
PostPosted: Sun Aug 22, 2004 6:33 am
i know that the wattage was important but i thought that more important was the amperage on each rail
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Sun Aug 22, 2004 1:12 pm
the power is the summation of the current x voltage on each rail, but the latter is a better indication of a good power supply because it allows less scope for the manufactures to bodge the values and you can also judge if the power is there where you need it (i.e on the 12V rail not the 5V rail)
PostPosted: Sun Aug 22, 2004 1:15 pm
so then the more amperage , current , you have on the 12v rail the better . i suppose this is what you mean
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Sun Aug 22, 2004 8:14 pm
Yes you are correct, I believe that was stated by the others and didnt want to repeat that.
The generalisation of a good 325 watt power supply is just that a generalisation, I was more leaning to the power supply quality than output.
J.C.GARCIA wrote:
so then the more amperage , current , you have on the 12v rail the better. i suppose this is what you mean
I believe webster was giving that as an example of what your system requires.
The begining of this post does show how you can figure it out simply but its not very accurate since it doesnt pertain to specific values and what amounts you need per rail
I have a web page that has a chart, although its not complete its has a printable chart and other tidbits.
http://www.angelfire.com/ex/kltsin/psu_info.html
I will try and get it updated to have more cpus and graphics cards shortly.
Also I don't know if any one covered this, when you find the total draw of a system you may want to multiply that by .15 and add it to the minimum required wattage for upgrading purposes
PostPosted: Fri Sep 10, 2004 12:25 am
here the #1 website on how to determine what wattage u need: check it out.
http://pcpowercooling.com/products/powe ... /index.htm
and then check out the nice psu they have, the turbo cool is the model that you should be looking for.
http://pcpowercooling.com/home.htm good luck.
look for
braided cables, high wattage 425w and above, numeroud inputs and are very silent.
Seeding 24/7 with an Argol slot, leech from the best seed to the rest
