It is currently Tue Feb 19, 2019 9:12 am
PostPosted: Fri May 17, 2002 9:26 pm
Guys,
Can you extend an ethernet cable by taking a phone line, and using it's wires to extend the ethernet cable wiring? (I know that ethernet has 8 connections and phone has 4, so you need two phone lines per ethernet) but will this result in a degration of performance, or will it simply not work?
Andrey
________
Ford EcoSport specifications
PostPosted: Fri May 17, 2002 9:31 pm
It'll work for 10Mbps cable because only 4 wires are actually used, but 2 phone cords would work aswell.
The only problem is that they are not sheilded so anything that emits some sort of electric field, would be affected...
Pin Name Description
1 TX+ Trancieve Data+
2 TX- Trancieve Data-
3 RX+ Receive Data+
4 n/c Not connected
5 n/c Not connected
6 RX- Receive Data-
7 n/c Not connected
8 n/c Not connected
Last edited by Hardware Junkie on Fri May 17, 2002 9:35 pm, edited 1 time in total.
PostPosted: Fri May 17, 2002 9:35 pm
so using 4 lines will give me 10 MBPS, and using 8 lines will give me 100 MBPS? or does the speed depend on the wiring involved?
any way to shield it? say wrap it in electrical duct tape?
________
juggalo
PostPosted: Fri May 17, 2002 9:38 pm
I wouldn't even try sheilding the cable...you would need to wrap it in foil and stuff...etc...not worth it. Electical tape would not cover it...
8 wires is used for 100Mbps...
PostPosted: Fri May 17, 2002 9:57 pm
thanks for the help!
what would be considered enough electrical interference to affect the data quality? simply having it near the computer? or a lightning storm?
________
Dongfeng Honda Automobile Company specifications
PostPosted: Fri May 17, 2002 10:15 pm
Wrapping the phone cord in a circle, or passing by a lamp or fan or TV...anything that transmits electricity.
PostPosted: Sat May 18, 2002 3:19 am
Just a question...
....why do you need to use telephone cable instead of cat5e cable?
Given the low cost of the networking cable and its wide availability, it just seems so much easier to do it right. Almost any length of un-twisted cable will degrade performance and the difference in resistance on the different gauge wires will also degrade your throughput.
reader
_ _ _____ _ _
"There we were, lost in the Wilds of Afghanistan without a corkscrew. Forced to live for days on nothing but food and water."
W.C. Fields
PostPosted: Sat May 18, 2002 10:47 am
I think it would be just cheaper for me. I have a short amount of cat5, and alot of telephone wires. I need about 75 feet of cable in order to get from the basement where my hub is, to my room where the computer will move to. I figured it would be cheaper to just splice the cable in the middle and add the phone lines to lengthen it.
________
star craft replays
PostPosted: Sat May 18, 2002 11:33 am
I've got a similar problem with getting the DSL to my sister upstairs for access. I was going to use the existing phone line that goes to her room to give her access.
Just have not given it a try yet.
Give it a try, but good luck...
PostPosted: Sun May 19, 2002 4:47 pm
It should work to use the phone line, but I agree that the low cost of using the correct cable is more than justified by the better throughput and less data errors. BTW, 100 mbps is only possible on cat 5 cable. The twist ratio reduces crosstalk and interference from external sources to make the additional speed possible.
