Athlon processor specifications, settings & information.
J.C.GARCIA
Post by J.C.GARCIA »
i have been given a mobo with an amd processor . on the mobo it is clerly marked K7T266 PRO VER 2.0 . on the top right it has a merking with the following 6380-20c . the board is by msi .on the startup screen i get the following
A6380VMS V3.4 013102
ATHLON AMD 1150 MHZ
the fsb is set to 100(200)mhz with current speed 1150 mhz
i installed the msi infoview xp utility and it gives me also the above info .
i set the fsb to 133mhz and on the startup screen i get the following
AMD ATHLON XP 1800+
In the msi infoview xp utility it tells me that the external clock is 133(266) mhz and the current speed is 1533mhz . i know that this board supports both 100 and 133 ( 200 and 266 ) fsb's but which one would be the default :?: and would the processor speed be 1150 mhz :?: and it goes up to 1800 once overclocked :?: i just want to know the processor speed without actually having to remove the processor . this is my first go at amd so please bear with me . i hope i havent made it confusing :wink:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
bdub
Post by bdub »
you've got an amd xp1800+ in there, the default fsb should be 133. those are the correct settings, 100 fsb would be underclocking the chip. 1533mhz is the processor speed at 133 fsb.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
J.C.GARCIA
ok thanks :wink:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
bigdog10
Post by bigdog10 »
Anyone have the MOBO Bios setting for this AMD 64 config
Corsair XMS Extreme Memory Speed Pro Series, Low Latency (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-3200PRO
ABIT K8T800 Chipset Motherboard for AMD Socket 754 CPU, Model "KV8-MAX3"
AMD Athlon 64 3400+, 1MB L2 Cache, 64-bit Processor
Post by Mr T »
opteron
AMD Opteron™ Processor Specifications
The operating specifications of an AMD Opteron™ processor can be determined by the processor's Ordering Part Number (OPN), which is located on the processor. Valid OPN examples for AMD Opteron processors are included below, as well as a brief chart that details how to read an OPN. For additional information, see the processor's technical documents, which can be downloaded from the Technical Documents page for the AMD Opteron Processor.
Note: The operating temperature of a processor is highly dependent on the induced workload, ambient temperature, and the efficiency of the cooling sub-system. However, the operating temperature should never exceed the processor's specified maximum operating temperature rating. For optimal performance, use a heatsink solution evaluated and recommended by AMD. A list of these recommended solutions is available on AMD's Thermal Solutions pages for the AMD Opteron processor.
AMD Opteron Processors OPN Model Operating Freq. Operating Voltage Case Temp. L2 Cache Package
OSA848CEP5AM 848 2200MHz 1.50V 70º C 1MB 940-Pin CμPGA
OSA846CEP5AM 846 2000MHz 1.50V 70º C
OSA844CEP5AM 844 1800MHz 1.50V 70º C
OSA844CCO5AI 844 1800MHz 1.55v 69º C
OSA842CEP5AM 842 1600MHz 1.50V 70º C
OSA842CCO5AI 842 1600MHz 1.55V 69º C
OSA840CEP5AM 840 1400MHz 1.50V 70º C
OSA840CCO5AI 840 1400MHz 1.55V 69º C
OSA248CEP5AL 248 2200MHz 1.50V 70º C 1MB 940-Pin CμPGA
OSA246CEP5AL 246 2000MHz 1.50V 70º C
OSA244CEP5AL 244 1800MHz 1.50V 70º C
OSA244CCO5AH 244 1800MHz 1.55V 69º C
OSA242CEP5AL 242 1600MHz 1.50V 70º C
OSA242CCO5AH 242 1600MHz 1.55V 69º C
OSA240CEP5AL 240 1400MHz 1.50V 70º C
OSA240CCO5AH 240 1400MHz 1.55V 69º C
OSA148CEP5AK 148 2200MHz 1.50V 70º C 1MB 940-Pin CμPGA
OSA146CEP5AK 146 2000MHz 1.50V 70º C
OSA144CEP5AK 144 1800MHz 1.50V 70º C
OSA142CEP5AK 142 1600MHz 1.50V 70º C
OSA142CCO5AG 142 1600MHz 1.55V 69º C
OSA140CEP5AK 140 1400MHz 1.50V 70º C
OSA140CCO5AG 140 1400MHz 1.55V 69º C
How to Read an OPN
OPN Example of an AMD Opteron Processor OSA 848 C E P 5 AM
OSA Brand:
OSA = AMD Opteron™ Server
848 Model Number:
Uni-Processor Models
140 = 1400MHz
142 = 1600MHz
144 = 1800MHz
146 = 2000MHz
148 = 2200MHz
Dual-Processor Models
240 = 1400MHz
242 = 1600MHz
244 = 1800MHz
246 = 2000MHz
248 = 2200MHz
Multi-Processor Models
840 = 1400MHz
842 = 1600MHz
844 = 1800MHz
846 = 2000MHz
848 = 2200MHz
C Package Type:
C = 940 Pin Lidded CuPGA
E Operating Voltage:
C = 1.55V
E = 1.50V
P Case Temperature:
O = 69º Celsius
P = 70º Celsius
5 Size of L2 Cache:
5 = 1 MB
AM Part Definition:
AH = CPUID Model 5, 2P, Rev B3
AL = CPUID Model 5, 2P, Rev C0
AG = CPUID Model 5, 1P, Rev B3
AK = CPUID Model 5, 1P, Rev C0
AI = CPUID Model 5, 8P, Rev B3
AM = CPUID Model 5, 8P, Rev C0
Athlon64
AMD Athlon 64 FX Processors OPN Model Operating Freq. Package Operating Voltage Case Temp. L2 Cache
ADAFX51CEP5AK FX51 2200MHz 940-Pin μPGA 1.50V 70º C 1MB
AMD Athlon 64 Processors OPN Model Operating Freq. Package Operating Voltage Case Temp. L2 Cache
ADA3400AEP5AP 3400+ 2200MHz 754-Pin μPGA 1.50V 70º C 1MB
ADA3200AEP5AP 3200+ 2000MHz 754-Pin μPGA 1.50V 70º C 1MB
ADA3000AEP4AP 3000+ 2000MHz 754-Pin μPGA 1.50V 70º C 512KB
How to Read an OPN
OPN Example of an AMD Athlon 64 Processor ADA FX51 C E P 5 AK
ADA Brand:
ADA = AMD Athlon™ 64 Desktop
FX51 Model Number:
FX51 = 2200MHz
3400 = 2200MHz
3200 = 2000MHz
3000 = 2000MHz
C Package Type:
A = 754 Pin Lidded OuPGA
E = 1.50V
P Case Temperature:
P = 70º Celsius
5 Size of L2 Cache:
5 = 1 MB
4 = 512 KB
AK Part Definition:
AK = CPUID Model 5
AP = CPUID Model 4, P-state transition support
Athlon MP
AMD Athlon MP Processors Core OPN Model Operating Freq.(MHz) Clock Mult. Nominal Voltage Max Die Temp. FSB Freq.(MHz) L2 Cache
Model 10 AMSN2800DUT4C 2800+ 2133MHz 16x 1.60V 90º C 266MHz 512KB
Model 8 AMSN2600DKT3C 2600+ 2133MHz 16x 1.65V 90º C 266MHz 256KB
AMSN2400DKT3C 2400+ 2000MHz 15x
AMSN2200DKT3C 2200+ 1800MHz 13.5x
AMSN2000DUT3C 2000+ 1667MHz 12.5x 1.60V
Model 6 AMP2100DMS3C 2100+ 1733MHz 13x 1.75V 95º C 266MHz 256KB
AMP2000DMS3C 2000+ 1667MHz 12.5x
AMP1900DMS3C 1900+ 1600MHz 12x
AMP1800DMS3C 1800+ 1533MHz 11.5x
AMP1600DMS3C 1600+ 1400MHz 10.5x
AMP1500DMS3C 1500+ 1333MHz 10.0x
AHX1200AMS3C N/A 1200MHz 9x
AHX1000AMS3C N/A 1000MHz 7.5x
How to Read an OPN
OPN Example of an AMD Athlon MP Processor AMSN 2800 D U T 4 C
AMSN Architecture Segment:
AMSN = AMD Athlon™ MP Processor (Model 8)
AMP/AHX = AMD Athlon™ MP Processor (Model 6)
2800 Model Number: 1500+ to 2800+ and above
D Package Type:
A = PGA
D = OPGA
U Operating Voltage:
U = 1.60V
K = 1.65V
M = 1.75V
T Die Temperature:
T = 90 Degrees Celsius
S = 95 Degrees Celsius
4 Size of L2 Cache:
3 = 256KB
4 = 512KB
C Max FSB:
C = 266MHz
All found here
http://139.95.253.214/SRVS/CGI-BIN/WEBC ... =OBJ(2132)
Post by Mr T »
sSpec# CPU Speed Bus Speed Mfg. Tech Stepping Cache Size Package Type
SL793 3.40 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA
SL7B9 3.40E GHz 800 MHz 90 nm C0 1 MB 478 pin PPGA
SL792 3.20 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA
SL6WG 3.20 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL7B8 3.20E GHz 800 MHz 90 nm C0 1 MB 478 pin PPGA
SL6WE 3.20 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA
SL6JJ 3.06 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6PG 3.06 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6S5 3.06 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6K7 3.06 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6SM 3.06 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6QC 3.06 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL78Z 3 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA
SL6WU 3 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA
SL6WK 3 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL79L 3E GHz 800 MHz 90 nm C0 1 MB 478 pin PPGA
SL6SL 2.80 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6WT 2.80 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6WJ 2.80 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6PF 2.80 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6S4 2.80 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6HL 2.80 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6Z5 2.80 GHz 800 MHz 0.13 micron M0 512 KB 478 pin PPGA FC-PGA2
SL79K 2.80E GHz 800 MHz 90 nm C0 1 MB 478 pin PPGA
SL6K6 2.80 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL7D8 2.80A GHz 533 MHz 90 nm C0 1 MB 478 pin PPGA
SL6QB 2.80 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6PE 2.66 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6SK 2.66 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6QA 2.66 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6DX 2.66 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6EH 2.66 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6S3 2.66 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6SB 2.60 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6QR 2.60 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6WH 2.60 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6HB 2.60 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6WS 2.60 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6GU 2.60 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6PP 2.60 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6S2 2.53 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6PD 2.53 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6Q9 2.53 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL685 2.53 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6SJ 2.53 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6EG 2.53 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6D8 2.53 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL682 2.53 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6DW 2.53 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6EV 2.53 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6PN 2.50 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6QQ 2.50 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6SA 2.50 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6GT 2.50 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6EB 2.50 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6EF 2.40 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6Q8 2.40 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL66T 2.40 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6PM 2.40 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6QP 2.40 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL684 2.40 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6E9 2.40 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6RZ 2.40 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6D7 2.40 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL67Z 2.40 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6PC 2.40 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6S9 2.40 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6SH 2.40 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL68T 2.40 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL67R 2.40 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6SR 2.40 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6WF 2.40 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6WR 2.40 GHz 800 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6Z3 2.40 GHz 800 MHz 0.13 micron M0 512 KB 478 pin PPGA FC-PGA2
SL79B 2.40B GHz 533 MHz 0.13 micron M0 512 KB 478 pin PPGA
SL6GS 2.40 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6DV 2.40 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL7E8 2.40A GHz 533 MHz 90 nm C0 1 MB 478 pin PPGA
SL65R 2.40 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6EU 2.40 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6ET 2.26 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6PB 2.26 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6DU 2.26 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL683 2.26 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6EE 2.26 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6Q7 2.26 GHz 533 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6RY 2.26 GHz 533 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6D6 2.26 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL67Y 2.26 GHz 533 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL5YS 2.20 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6E8 2.20 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL68S 2.20 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6GR 2.20 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6PL 2.20 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6QN 2.20 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL66S 2.20 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6S8 2.20 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL5ZU 2.20 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL5ZT 2 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL5UH 2 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL5TQ 2 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL6E7 2 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6GQ 2 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL68R 2 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL62Q 2 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL5YR 2 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL6PK 2 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL5SZ 2 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL6QM 2 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6S7 2 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL5TL 2 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL6SP 2 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL66R 2 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL67C 1.90 GHz 400 MHz 0.18 micron E0 256 KB 478 pin PPGA FC-PGA2
SL6BF 1.90 GHz 400 MHz 0.18 micron E0 256 KB 478 pin PPGA FC-PGA2
SL5WH 1.90 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL5WG 1.90 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL5VN 1.90 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL5VK 1.90 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL66Q 1.80 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL5UM 1.80 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL67B 1.80 GHz 400 MHz 0.18 micron E0 256 KB 478 pin PPGA FC-PGA2
SL63X 1.80 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL5UT 1.80 GHz 400 MHz 0.18 micron C1 256 KB 478 pin PPGA FC-PGA2
SL5UV 1.80 GHz 400 MHz 0.18 micron C1 256 KB 478 pin PPGA FC-PGA2
SL4WV 1.80 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL62R 1.80 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL68Q 1.80 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL62P 1.80 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL5UK 1.80 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL6BE 1.80 GHz 400 MHz 0.18 micron E0 256 KB 478 pin PPGA FC-PGA2
SL6E6 1.80 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6LA 1.80 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA
SL6PQ 1.80 GHz 400 MHz 0.13 micron D1 512 KB 478 pin PPGA FC-PGA2
SL6QL 1.80 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL6S6 1.80 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL5VM 1.80 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL6SN 1.80 GHz 400 MHz 0.13 micron C1 512 KB 478 pin PPGA FC-PGA2
SL4X5 1.80 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL5VJ 1.80 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL5TK 1.70 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL59X 1.70 GHz 400 MHz 0.18 micron C1 256 KB 478 pin PPGA FC-PGA2
SL57V 1.70 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL62Z 1.70 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL5TP 1.70 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL5SY 1.70 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL67A 1.70 GHz 400 MHz 0.18 micron E0 256 KB 478 pin PPGA FC-PGA2
SL5N9 1.70 GHz 400 MHz 0.18 micron C1 256 KB 478 pin PPGA FC-PGA2
SL57W 1.70 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL6BD 1.70 GHz 400 MHz 0.18 micron E0 256 KB 478 pin PPGA FC-PGA2
SL5UG 1.70 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL5UJ 1.60 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL4X4 1.60 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL5UL 1.60 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL5US 1.60 GHz 400 MHz 0.18 micron C1 256 KB 478 pin PPGA FC-PGA2
SL5UW 1.60 GHz 400 MHz 0.18 micron C1 256 KB 478 pin PPGA FC-PGA2
SL5VH 1.60 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL5VL 1.60 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL62S 1.60 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL4WU 1.60 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL668 1.60 GHz 400 MHz 0.13 micron B0 512 KB 478 pin PPGA FC-PGA2
SL679 1.60 GHz 400 MHz 0.18 micron E0 256 KB 478 pin PPGA FC-PGA2
SL6BC 1.60 GHz 400 MHz 0.18 micron E0 256 KB 478 pin PPGA FC-PGA2
SL5SX 1.50 GHz 400 MHz 0.18 micron D0 256 KB 423 pin PPGA INT3
SL5N8 1.50 GHz 400 MHz 0.18 micron C1 256 KB 478 pin PPGA FC-PGA2
SL5TJ 1.50 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL4X3 1.50 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL4SH 1.50 GHz 400 MHz 0.18 micron B2 256 KB 423 pin PPGA INT2
SL5TN 1.50 GHz 400 MHz 0.18 micron D0 0 KB 423 pin PPGA INT3
SL59V 1.50 GHz 400 MHz 0.18 micron C1 256K FC-PGA2 478-pin
SL4WT 1.50 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL5UF 1.50 GHz 400 MHz 0.18 micron D0 0 KB 478 pin PPGA FC-PGA2
SL62Y 1.50 GHz 400 MHz 0.18 micron DP 256 KB 478 pin PPGA FC-PGA2
SL4TY 1.50 GHz 400 MHz 0.18 micron B2 0 KB 423 pin PPGA INT2
SL59U 1.40 GHz 400 MHz 0.18 micron C1 256 KB 478 pin PPGA FC-PGA2
SL4SG 1.40 GHz 400 MHz 0.18 micron B2 256 KB 423 pin PPGA INT2
SL4X2 1.40 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL5N7 1.40 GHz 400 MHz 0.18 micron C1 0 KB 478 pin PPGA FC-PGA2
SL5TG 1.40 GHz 400 MHz 0.18 micron D0 256 KB 478 pin PPGA FC-PGA2
SL5UE 1.40 GHz 400 MHz 0.18 micron D0 0 KB 478 pin PPGA FC-PGA2
SL4WS 1.40 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL4SC 1.40 GHz 400 MHz 0.18 micron B2 0 KB 423 pin PPGA INT2
SL5FW 1.30 GHz 400 MHz 0.18 micron C1 256 KB 423 pin PPGA INT2
SL5GC 1.30 GHz 400 MHz 0.18 micron C1 256K OOI 423-pin
SL4SF 1.30 GHz 400 MHz 0.18 micron B2 0 KB 423 pin PPGA INT2
SL4QD 1.30 GHz 400 MHz 0.18 micron B2 256 KB 423 pin PPGA INT2
pentium 4 specs.....
All here....
http://processorfinder.intel.com/script ... kgType=ALL
bigdog10
Post by bigdog10 »
my AMD64 3400+ is running at 168^C
That seems high compared to your chart
Aussie
Post by Aussie »
Mate I think there would be some smoke if that temp reading was in fact true. 8O
Aussie
Contact:
Post by evasive »
Oh great, finally when Asus is getting their act together on bios temps, here comes Abit to do the same routine all over again! :roll:
Post by Mr T »
ALL Athlon XP-M's have either a 100MHz or 133MHz FSB - the parts you mentioned(2400-3000) all have a 133MHz FSB.
Clockspeeds:
AXP-M 2400+(Model 10) -> 1.80GHz(133x13.5)
AXP-M 2400+(Model 8) -> 2.00GHz(133x15.0)
AXP-M 2500+(Model 10 only) -> 1.86GHz(133x14.0)
AXP-M 2600+(Model 10) -> 2.00GHz(133x15.0)
AXP-M 2600+(Model 8) -> 2.13GHz(133x16.0)
AXP-M 2800+(Model 10 only) -> 2.13GHz(133x16.0)
AXP-M 3000+(Model 10 only) -> 2.20GHz(133x16.5)
Mobile specs...
Post Reply
