İstanbul Escort Bayan
It is currently Fri Mar 22, 2019 12:39 pm
PostPosted: Wed May 15, 2002 7:02 am
It comes with a 330w from newegg, but i don't want to waste money and a halfassed ps. What did you do Tolemac? I believe you have this case.
PostPosted: Wed May 15, 2002 10:47 am
Yes indeed I have this case. It comes with the Enermax EG351 psu, which is a good power supply. The one that I got ended up being bad (hey, it happens) so I rma'd it and Newegg, being the customer service oriented company that they are, sent me the EG365 350W power supply. :wink:
Damn good of them if you ask me. If you really don't want that power supply, then go here and check out the Chieftech DX-01WD. It is the exact same case, but without the power supply and the Enermax logo. Only $45.00 8)
The Gift of Healing
Conscious Energy Meditation
PostPosted: Wed May 15, 2002 12:05 pm
awwhaw, hawhaw, hehehe *salivates* mmmmmm num num. Tolemac, you hit the nail on the head. I was about to say too bad it's not black, then I clicked the one below it. 8)
Edited 5/16/02 4:18am Central Standard time
:!: WAIT! :!:
Where can I get one with out those darn sleeve bearing fans as well :?: :?: :?:
PostPosted: Sat May 18, 2002 12:50 am
Nothing wrong with the sleeve bearing fans at all. Very quiet and they do the job. If it is really gonna bug you, then get a couple of the Enermax UC-8FAB adjustable speed ball bearing fans. Only $7.00 ea. @ Newegg. 8)
The Gift of Healing
PostPosted: Sat May 18, 2002 7:42 am
:arrow: :idea: chieftec cases come w/o psu, you'll have to buy a couple of case fans as well (80mm)-btw i've got the enermax 330w2bbfan psu w/ fs-710 case (w/ 3sleeve case fans- bought 1 bb fan for hdd cooling)- seems to work ok- from what i hear enermax is one of the better psu's out there. some of the newer cases come w/ a usb plug in front, whereas the one i've got doesn't- might want to verify that beforehand.
http://www.newegg.com/
