It is currently Sun Sep 23, 2018 4:18 pm
 Post subject: NORTON
PostPosted: Sun May 12, 2002 2:18 pm
I JUST GOT NORTON SYSTEMWORKS 2002. INSTALLED IT AND SEEMED TO WORK FINE. THEN STARTED TO HAVE A FEW POUBLEMS. THEN TALKED TO OTHERS, AND FOUND OUT NORTON AND WINDOWS, WELL, FIGHT A LOT. IS THIS TRUE? AND ANY WAY AROUND IT? DO I NEED TO DUMP NORTON, AND IF SO REPLACE IT WITH???????? THANKS JOHN 003 :wink:
PostPosted: Sun May 12, 2002 3:39 pm
I am running Windows Xp Pro with Nortons System Works 2002 and have had no problems so far.
What problems have you been having??
Are the people with probs running full versions of Nortons or beta versions?
I regularly update my versions through live update and to date all is well!!
I would be interested to know what problems you heard about or are having maybe I can be of help??
:D
Windoze Xp Pro Sp2/Vista Dual Boot System
Amd 64 Athlon 3200+
MSI K8TNeo MotherBoard
2 Gb Pc3200 Ram 400Mhz Clock Speed
40Gb Xp Dve/80Gb Vista Dve
120Gb 7200 Ide Slave Dve
500Gb Sata II 7200 16Mb Cache Slave Dve
19" Sony G420 Multiscan Trinitron Monitor
400 Watt P/S
 Post subject: Internet related
PostPosted: Sun May 12, 2002 3:57 pm
Most of the problems people have been noting are because of the Windows XP built in Firewall and Norton conflicting. Or Norton completely denying access to the internet, etc...
These are only in a few cases though. You shouldn't have many problems
PostPosted: Sun May 12, 2002 4:15 pm
Well, if all else fails you could try McAfee online. I've been using that for 2 years now and haven't had any problems.
PostPosted: Mon May 13, 2002 2:55 am
My experience has been that Norton SystemWorks 2002 and Windows XP get along fine but Norton SystemWorks 2002 and Windows 98 is big trouble.
SystemWorks 2001 and Windows 98 are fine.
I never use Windows XP's built-in firewall I prefer ZoneAlarm.
Aussie
 Post subject: norton
PostPosted: Mon May 13, 2002 7:41 am
Sorry I gorgot to say have 98SE. at the beginning every thing was fine, but then files went missing and it seemed norton didn'tcare, and applactions could not open without them. Dll's were gone and unreplacable. And norton seemed to be finding all these proublems and fixing them all the time, was wondering where all the proublems came from. Thanks JOHN 003
PostPosted: Mon May 13, 2002 9:49 am
i have a dual boot system running win98se and win2000pro w/ norton system works 2002, and don't have any problems.
if you have 512meg ram or higher (think it will do up to 1.5 gig) w/ win98, you'll want to adjust your vcache settings!
