It is currently Sat Mar 28, 2020 4:27 pm
 Post subject: Zalman GT1000
PostPosted: Wed Nov 29, 2017 1:10 pm
As mentioned in a previous post, I'd like to make use of this case, but it's old so I'm having trouble checking compatibility.
I've bought an i5-6500, and EVGA GTX-1050 Ti, and will probably get a Corsair VS 650w PSU.
I'm hoping to use the GT1000 and a Zalman (CNPS7000C I think) I already have.
It's for my OH to play Arma III. I suspect FPS won't be great, but he'll likely not be playing on crowded servers/maps... (please be kind..)
Please can you suggest decent motherboard (Asus Z170 of of some sort maybe?) and RAM (something like this perhaps?). I'll probably buy used.Was hoping to keep it under £400 but spent over £300 already (allowing for PSU). Worried I've messed up, but if it's not good enough for Arma, we can still use it.
Thank you.
Asus M4A78T-E
Phenom II x3 720
R7 200 series
16GB RAM (Crucial 4x4)
Antec Earthwatts 500W
 Post subject: Re: Zalman GT1000
PostPosted: Thu Nov 30, 2017 6:45 am
Can't comment about motherboards, but based on the benchmarks and videos I've seen of Arma3 being played on much lower GPUs...I really don't think you're going to have problems with it running. The CPU hits it's base requirements easily, and the GPU is approximately 3-4 models above many of the gameplay footage vids I've seen(think 600 or 700 series geforces) where they are getting 75+ FPS.
Make sure you don't skimp on the amount of RAM you get - try for 8gb if possible. I've used gskill a lot in the past and had good results.
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Fri Dec 01, 2017 12:45 am
Thanks Roach, that's very reassuring :)
Trying to find RAM now that isn't too high voltage for the CPU... proving to be a bit tricky :s
Asus M4A78T-E
Phenom II x3 720
R7 200 series
PostPosted: Fri Dec 01, 2017 9:02 am
With the memory controller on the CPU die, lower voltage is mandated. Typically about 1.1 volts to 1.7 volts range.
If memory requires a higher base voltage, it can falter with paging.
Best to use the QVL (Qualified Vendor List) at the mobo manufacturer's Web site for recommended modules.
Corsair, G. Skill, Micron, OCZ, Muskin, Kingston and others are top-rated. But beware of any memory with a 'value' grade, as it may not have good stability above its rated speed.
PostPosted: Sat Dec 09, 2017 9:23 am
Thanks Karlsweldt. I saw your post a while back but have had a bit of a nightmare with mobo/RAM combo... :oops:
When I went for a DDR4 board, both the boards and RAM sticks I could find were too pricey for my budget, even used: or else just about every board I saw was 'micro', even when I'd specified ATX...
When I went for a DDR3 board, the problem of 'too high voltage' RAM kept cropping up. I was about to get some Corsair Vengeance DDR3L, but still couldn't get a mobo to pair it with lol.
So, I decided that I should really try and go for DDR4, or increasing RAM later could be a pain, plus DDR4 should be cheaper when that time comes..
Ergo, I got some cheapo green Crucial RAM, and will be getting an Asus Z170-P to stick it in. It's a tad bit smaller than the board that's in that case at present, but should be fine hopefully.. Your comments about value RAM concerned me Karlsweldt, but I believe I've negated the voltage issue by going for DDR4...?
I can't really afford an SSD right now I don't think.. so will probably re-purpose one we have lying around. Likewise Windows. Probably 7 if I can't get the Win10 key from a melted laptop. I'm anticipating problems with the old fan I want to use, but just going to wait till I have all the components then cross any hurdles as I come to them.. Yeah I know, haphazard or what.. :/
Asus M4A78T-E
Phenom II x3 720
R7 200 series
PostPosted: Sun Dec 10, 2017 8:46 am
To clarify that notation about 'value' grade memory, the chips are the same ones from the same batch of chips that are higher rated in speed and voltage for desired CAS, RAS, and other timings. There may be one chip that is either under-rated or over-rated a bit. The best quality chips go for premium production, while the lesser quality chips are for that 'value' grade production rather than being scrapped.
PostPosted: Sun Dec 24, 2017 2:10 am
Finally all done! :)
Asus - Z170-P ATX LGA1151 Motherboard
Intel - Core i5-6500 3.2GHz Quad-Core Processor
ARCTIC - Alpine 11 GT CPU Cooler
EVGA - GeForce GTX 1050 Ti 4GB SC GAMING
Corsair - VS 650W ATX PSU
Crucial - 8GB (1 x 8GB) DDR4-2400
WD - Caviar Blue 1TB 3.5" 7200RPM
SAMSUNG SyncMaster 2243BW 22" TFT-LCD
Windows 10 Home
I was a little worried when there were 3 'spare' standoffs in my case, but research revealed this wasn't unusual with some slimmer boards (just be careful plugging in the main power connector! Or plug things in before installing the board :roll: )
It wouldn't fire up at first, then I imagined a nightmare trying to figure out which part was not right, but the strange noise from the DVD Rom told me that it was probably that. The other drives I had lying around were IDE, so the next hurdle was figuring out how to get an OS onto it.. Bought a stick and downloaded Win10.
Half the parts were used (mobo, CPU, GPU, monitor), so it came in at a touch over £500. Re-purposed GT1000 case, wireless card, speakers, gaming mouse & keyboard. I've ordered a little extension cable as the ones on the front fans won't reach the board, and I'll probably get a new DVD drive and perhaps some kind of USB hub/card reader-type thing to replace the 2 duff drives I'm going to stick in there for now, just for aesthetic purposes. I stupidly thought I'd use an old monitor but didn't think of the VGA/DVI issues until very late in the day :oops: Managed to get one locally cheap (£40), and they offered me a couple more for free! but I gave them £20. It's a bit bigger than mine and may have some other display-related benefits I'm not yet really aware of (digital, higher res, something like that..) so I'll get a little upgrade too, as will one of the boys.
Anyway, thanks ever so much for your help guys. Some of the RAM info. went a bit over my head, but I guess the gist is 'you get what you pay for' (which isn't always the case but hey-ho) I'm going to think of it this way: I might have got a stick of RAM that could've been twice as much had it had nice little jackets on it. Okay, you can stop laughing now! :D
Happy Christmas!
Asus M4A78T-E
Phenom II x3 720
R7 200 series
