It is currently Sat Mar 28, 2020 2:55 pm
PostPosted: Tue Sep 26, 2017 8:27 pm
I have windows 10 and Google Chrome installed. When I X off a website and then click on the Google icon it takes me back to the previous website or page I was on. What I want it to do is return me to the Google start page. I can't find the setting to make that change. Is this a Windows setting or a Google setting?
Where do I make this setting change?
Thanks.................
PostPosted: Wed Sep 27, 2017 1:08 pm
that's definitely a setting within chrome.
go to your chrome settings, and at the bottom (just above the "advanced" option) there's one called "on startup".
clicking on that should provide you with the options to:
open new tab page
continue where you left off
open specific page or set of pages
I'm assuming yours is set to "continue where you left off" - just change it to the last one, and provide your homepage as the one you want (easiest to do it after you are already on the page you want, because it gives you the option for "use current pages").
-R
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Mon Oct 09, 2017 7:38 am
Re: To deleted post by adibitar69:
NO ADVERTISING LINKS TO OTHER SITES UNLESS PRE-APPROVED BY ADMINISTRATOR..
IN SIGNATURE OR ELSEWHERE!!
Users browsing this forum: MegaIndex.ru [Crawler] and 3 guests
