It is currently Fri Apr 03, 2020 3:45 am
PostPosted: Fri Jul 07, 2017 5:44 pm
Recently bought 2k(1440p) resolution monitor and set it up on 2 PC's, one of them r9 390x and another HD5850 which instead 2k res shows just 1920x1200 by HDMI cable.
Couldn't figure out what's wrong. I know Max res of it is 2560x1600. Guys told me it might be outdated HDMI port and recommended use DVI but i couldn't because no DVI port at display, just DP and HDMI.
Any help would be appreciated.
Thanks.
PS. FIXED
PostPosted: Mon Jul 10, 2017 7:07 am
Latest driver set for that HD5850? Per this specs link, the card is capable of very high resolution..
http://www.amd.com/en-gb/products/graph ... 5000/5850#
But a footnote indicates 'user configuration' may be required!
PostPosted: Mon Jul 10, 2017 8:20 am
check your HDMI cable - version 1.2 only goes up to 1920×1200p/60 Hz, you need at least 1.3+ to get up to 2560×1600p/60 Hz, and you won't see certified 4k until you get to version 2.0 I think. you might be able to get away with some hi-speed versions below 2.0, but your mileage may vary...
-R
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
