It is currently Sat Aug 18, 2018 2:16 pm
PostPosted: Sun Oct 09, 2016 2:09 pm
Wellsir ... my main computer (the intel i7) hard drive gave out on me and I can't boot into windows anymore. Meaning I must replace the hard drive and reinstall everything again including my flight sim which is going to be a royal pain in the rear :roll: . I'm tried of doing that when the hard drive fails. I tried to do a back up on my AMD computer now that I have it up and running again after replacing the hard drive, but I got an error about windows backup failed while trying to read from the shadow copy on one of the volumes being backed up. I don't know what to do about that. I got this paragon hard disk manager 15 suite, but I don't know how to use it yet. Can anyone help me out with this? :?
Main Rig_Intel i7 4770k@3.50
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
WD100000 SATA 7200RPM
Seagate 1TB SATA 7200RPM
Corsair CX750M
Win7 Ultimate x64
Rig2_AMD FX8120
GIGABYTE GA-M68MT-S2 Mobo
4Gb DDR3 1600
ZOTAC GeForce GTX 550TI
Rosewill M650
Win7 64
PostPosted: Sun Oct 09, 2016 3:32 pm
Certain the hard drive is totally dead? Tried another power lead, another data ribbon?
If you hear clicks and buzzing from the drive, then most likely it is DOA.
Check with the manufacturer, if there is a warranty left. Data recovery is expensive.
PostPosted: Mon Oct 10, 2016 7:13 am
Pretty sure the hard drive has gone bad. When it first started to act up I tried testing it with the WD diagnostic, but it seem like it was not doing anything. I wasn't able to cancel the test and when I did a reset to get the computer going again it would no longer boot into windows. I tried to do a repair, but it didn't do anything for hours.
I'm waiting for the replacement drive ... I just want to learn how to back up my OS so I won't have to go through a fresh install each time the hard drive goes. I don't understand why my AMD computer couldn't do a backup. I need to figure out this imaging software so I can backup the OS. I got the drive in 2013 so the warranty has expired. The WD green only has a two year on it.
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
Win7 Ultimate x64
Rig2_AMD FX8120
4Gb DDR3 1600
Rosewill M650
Win7 64
PostPosted: Mon Oct 10, 2016 3:38 pm
A hard drive will spin up with just the power connection, no data ribbon.
Trying another power lead is the easiest test to see if a drive is still good.
With SATA drives, there is only one way to connect the data ribbon. With the older PATA type, 40-wire, there were some headers that had no physical key to ensure the proper connection. That red stripe should always be nearest the power socket, and at the pointer for #1 on the mobo header. Jumper settings for stand-alone, master/slave and cable select must be checked.
With the 80-wire ribbons, there is a dedicated connector for master and slave, and mobo header.
Some newer SATA drives may not be recognized on older systems, so there may be a jumper to set previous standards.
Cloning software is the best and most complete way to back up a system, down to enabling the other drive to boot.
If the drive is out of warranty, perhaps a "transplant" of the disk(s) to another identical drive may regain data access. A level 4 (ultra clean) service area is mandated. One tiny speck of dust getting on the platter and hitting the heads is like a car hitting a boulder on the highway.
PostPosted: Mon Oct 10, 2016 6:16 pm
I'll double check the cable ... is this paragon program what I need to clone my drive?? :-|
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
Win7 Ultimate x64
Rig2_AMD FX8120
4Gb DDR3 1600
Rosewill M650
Win7 64
Users browsing this forum: Bing [Bot] and 3 guests
