Windows 10 Folder Icons
Postby c327 » Mon Oct 03, 2016 11:41 am
As it pertains to Windows 10.
I have one folder that has about 175 sub folders. I want to change the icons of all these folders to the same icon all at one time. I know how to do it individually but that is taking to long.
c327
Re: Windows 10 Folder Icons
Postby Karlsweldt » Mon Oct 03, 2016 3:50 pm
Tried the ancient "Ctrl+A" way (select all)?
Postby c327 » Tue Oct 04, 2016 2:45 am
Karlsweldt wrote:Tried the ancient "Ctrl+A" way (select all)?
Yes don't work
c327
Postby Karlsweldt » Tue Oct 04, 2016 5:10 am
Another way was to highlight one folder or file, then press the 'shift' key.. then choose another folder or file to highlight. Should highlight all within that group.
Some online links as to how-to. Maybe this one helps?
http://www.dummies.com/computers/operat ... indows-10/
Postby c327 » Wed Oct 05, 2016 4:20 pm
Karlsweldt wrote:Another way was to highlight one folder or file, then press the 'shift' key.. then choose another folder or file to highlight. Should highlight all within that group.
Thanks for the link but I want to change the folder icon, not rename the folder. What I want to do can be done individually but doing it that way is taking a ton of time. The original Winows 10 folder icons are hidious.
c327
Postby Karlsweldt » Thu Oct 06, 2016 7:46 am
A lot has changed in the way Win 10 works than older versions. Maybe too much of a "this way, our way" of thinking?
Some old methods should still be viable with renaming files or folders, or changing icons.
Postby evasive » Sun Jan 29, 2017 9:16 am
Return to General
