It is currently Sun Jan 20, 2019 1:30 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Wed Oct 05, 2016 4:03 pm
Only our Administrators have control over member partial or full Forum use.
Will have to PM one and see what can be done.
PostPosted: Thu Oct 06, 2016 9:15 am
Thanks a lot. I want to send you a link, but it's hard if I cannot PM... :(. Also, any comments about the first of my double posts? Not sure if that one got skipped, but still a bit upset I dropped my sound card... I'm going to plug it back in, and hope all is fine... :).
Thanks for everything.
PostPosted: Thu Oct 06, 2016 3:32 pm
Don't worry about a double posting. Happens sometimes, due to a software or ISP glitch.
Intentional double posting is a different matter that is frowned on.
PostPosted: Sun Oct 09, 2016 12:23 pm
The issue is that I cannot edit and I need to post something else, so it gets a double post... I wish that posts could get merged though, because I don't want to double post... And even if I Have a post, and have t oedit it, it needs moderator approval again, and I don't know if you have seen the post.. (which is why I would like to get approved to post without approval so I can edit and do other normal user things :) ).
Anyways, I don't think anything happened ot the card. I put it back in it's original slot, and it's working well now. I think I figured out which contacts were shorting out, and everything is working great now!
Sad I dropped it though... What's the worst you think could happen from a drop on to carpet? Static? Cap burst?
PostPosted: Sun Oct 09, 2016 3:15 pm
Hopefully, your full status will be soon.
Don't worry about posts needing approval if edited.
Should be no damage to a device card if dropped on a carpeted floor. But if dropped on a hard floor, some damage is likely.
But check the GPU fan if there is one, to ensure it is still solidly mounted and spins freely.
PostPosted: Thu Oct 13, 2016 7:20 am
Thanks for the info, the card is working better than ever. I realize which way it was popping out of the slot, and it seems to be working great in the original slot again, so that's great for me. This was a sound card, not a gpu, but thanks for the tip. I just didn't want caps to burst or something crazy.
