MS Access run-time error
Postby AimoSala » Mon May 16, 2016 4:33 am
Hello,
I have a database .mdb which has got corrupted (Error 3197). I can't open it. I have tried and searched any solution, but apparently there is no one.
Can somebody help me, please?
By the way, I found this solution in EE and even tried AccessRecovery 2.1, but no success.
MS Access database recovery steps:
1) Create a backup of the corrupt database. (Just in case of)
2) Create a new database and use File/Get external data/Import to get all objects of the damaged database.
3) Try these Microsoft solutions:
Repair A97/A2000:
http://support.microsoft.com/support/kb ... 9/9/53.asp
Jetcomp:
http://support.microsoft.com/default.as ... us;Q273956
and/or read the article:
ACC2000: How to Troubleshoot Corruption in a Microsoft Access Database
http://support.microsoft.com/default.as ... -us;306204
4) Bit "heavier":
Access decompile:
http://www.granite.ab.ca/access/decompile.htm
AimoSala
Re: MS Access run-time error
Postby evasive » Mon May 16, 2016 9:07 am
What are you using for backend, SQL, file if so, where is the file located? Has this ever worked? What changed?
Postby AimoSala » Fri May 20, 2016 4:52 am
file located on the local machine. It worked some time ago but now I get Error 3197 when opening it.
AimoSala
Return to General
