It is currently Fri Aug 07, 2020 1:13 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Fri Dec 04, 2015 9:21 am
Hi guys,
I am looking for the drivers to Gateway 6000609 03-0218-3A ISA-PCMCIA controller.
ISA card:
3.5 front-side bay:
Also 2x50wires flat cable (SCSI-like) - not pictured.
Googling for a few days now, but can't find anything...
Any help please? Thanks!!
PostPosted: Mon Dec 07, 2015 6:03 am
Welcome to Moterboards.org
take a look at:
http://drivers-11.blogspot.com/2013/11/ ... oller.html
-Wrapped Around Your Fingers-
-The Police-
PostPosted: Tue Dec 08, 2015 8:11 pm
take a look at:
Hi,
thanks for the reply. However there is NO drivers - there is a single .EXE file which will install "DriverUpdater PRO" loaded with a bunch of crapware.
Every page of that "drivers" website is pointing to the same .exe file. There is no actual drivers in there, sorry. :)
PostPosted: Wed Dec 09, 2015 12:24 pm
Gateway was the end user, not the manufacturer of the card.
Did some searching, possibly an ALR Legacy device at this site..
http://members.driverguide.com/driver_s ... ISA-PCMCIA
http://www.driverguide.com/driver/detai ... af1f0e192d
PostPosted: Wed Dec 09, 2015 12:33 pm
Taro1234 wrote:
take a look at:
Hi,
I´m sorry too :oops: I check the link and realizaed by muyself that was only a Fraud, perhaps in driverguide you can find something they are a good site for drivers from many years ago
-The Police-
PostPosted: Sun Dec 13, 2015 1:44 am
can you post the 47-**** part numer and any other numbers printed on the board? We might be able to find something that way. And I'll have to go through my offline files to see if by chance I ever downloaded something for that< I think I ever did a mirror of the ALR files by accident....
PostPosted: Sun Dec 13, 2015 7:26 am
47-0045-058Y
PostPosted: Sun Dec 13, 2015 8:37 am
The driveragent website gives a peek into the readme.txt that references the 6000609 card drivers and says it's an Action Tec PC750 drivers V2.44
Those can be found here:
http://driverzone.com/%7Bb99e4b23-ac04- ... id=2452309
These are windows 95 and windows 98 drivers. For a PCI card.
However there is an ISA model, the PC700 for which the specs are here:
http://support.actiontec.com/doc_files/ ... cument.pdf
It says it's plug-n-play so all you would need to do is install the drivers for whatever PCMCIA card you have into the reader.
Quote:
Technical Data
Interface: 16-bit ISA
Chipset: Vadem VG-469
Card Socket Type: 2 Type I or
2 Type II or
1 Type I / II and 1 Type III or
1 Type III
Supported Operating
Systems:
DOS, Windows 3.x, Windows 95/98, Windows NT 3.51/4.
0,
Windows 2000, OS/2 Warp 4
Configuration Modes: Plug-N-Play compatible
Basic Configurations (Win95 /98)
Basic Configuration
Input/Output
0000
03E0-03E1 *
All "*" items are capable of being manually change
d through Change Settings.
There's a PC300 model too but that talks about jumper settings while your card is jumperless
The more I read, the more I am confused. Can you give the markings from the chips that are on your card?
PostPosted: Wed Dec 16, 2015 9:17 am
evasive wrote:
http://driverzone.com/%7Bb99e4b23-ac04-40bd-8183-04faec2343ec%7D?id=2452309
Need DOS or Win3.1 drivers. :)
My comp is 386/33-8, so no luck with Win95.
Nothing special - those are 4 x 74HC245D
PostPosted: Sun Dec 27, 2015 3:00 am
That are very simple logic gates indeed so basically you would not need a driver for the interface, just for the PCMCIA card you insert in there then.
