merging two dvi ports to one....
Postby bdub » Wed May 27, 2015 6:30 am
...is there tech to make two dual link dvi outputs on a graphics card be combined to support a single 4k monitor, either by use of a 2xdvi/dp adapter of some sort or by two cables? I think I remember something about this being possible, but can't find any links.
thanks.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
bdub
Re: merging two dvi ports to one....
Postby evasive » Wed May 27, 2015 7:07 am
argh, reverse of what you want:
http://www.tomshardware.co.uk/answers/i ... ption.html
searching...
Postby Karlsweldt » Wed May 27, 2015 3:56 pm
Postby evasive » Wed May 27, 2015 10:13 pm
Same story: DP to Dual-DVI...backwards of what he wants.
Postby evasive » Wed May 27, 2015 10:19 pm
http://www.gefen.com/gefentv/gtvproduct ... od_id=9898
Or this and then combine the HDMI signals?
http://www.amazon.com/Cable-Matters%C2% ... itor+cable
What brand/model is your 4k monitor and what connection options do you have in there?
Postby bdub » Thu May 28, 2015 11:13 am
thanks for looking guys... don't really have an actual 4k monitor in mind exactly. this is in case legacy customers of ours wants to use 2 4k monitors with one of our machines already built, which we used to put lots of quadro's (quadro 2000 or 4000's) in that have 2 dvi ports and one DP. each dvi does less than 4k res, but I thought if we could combine the two outputs somehow, then the two of them together could do 4k spec. I thought this would be possible, but maybe I'm wrong. they will be able to run at least one though, through the dp port, so that's a plus. hoping to have seen a single, easy solution... not an external box, but pretty much just a cable adapter... I thought the driver's made by NVidia allow for such things.
it is possible some of the 4k monitors have two dvi inputs that might allow this, maybe?
my main rig...
asrock 970 extreme3
antec neo he 650r
bdub
Postby evasive » Thu May 28, 2015 9:57 pm
I think I am indeed seeing something like that when searching for info. You want me to check for that possibility?
Postby bdub » Fri May 29, 2015 3:27 am
any help is greatly appreciated. my searches are coming up null.
the best result would be something that fits our two dvi ports and will run a single dp cable end (or hdmi end, I guess) into any 4k monitor. that way end users can buy any 4k monitor and we can send them what needs to fit it.
but if 4k monitors natively do this with two dvi cables, that'd be a good answer, too... not the optimal outcome, but good to know. we don't send out UHD monitors yet, so have had no experience with that side.
TIA.
my main rig...
asrock 970 extreme3
antec neo he 650r
bdub
Postby evasive » Fri May 29, 2015 10:20 am
urgh, not something to be happy about but we're 1.5 years further now, is this "standard" still that broken?
back to the drawing board here. Karl thanks for posting those links...
Return to General
