It is currently Tue Mar 26, 2019 5:02 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Sat Mar 15, 2014 12:51 am
I have the Sound Blaster Live! 5.1 PCI card, when I try to install the driver I get a message that it could not locate the product. This is the mobo.
In the device manager the PCI input device doesn't have a driver and I haven't been able to find one for Win7 64bit. I'm wondering is that part of my problem? Also the multimedia audio controller doesn't have a driver. I don't have any sound. In the device manager under sound, the NVidia high definition audio is installed ... could that be causing a conflict? :-|
Main Rig_Intel i7 4770k@3.50
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
WD100000 SATA 7200RPM
Seagate 1TB SATA 7200RPM
Corsair CX750M
Win7 Ultimate x64
Rig2_AMD Ryzen 7 1700
MSI Gaming B350
16Gb DDR4 2133
ZOTAC GeForce GTX 550TI
Seagate BarraCuda Pro 4TB SATA 7200RPM
Inland 600 P/S
Win7 64
PostPosted: Sat Mar 15, 2014 1:03 am
What version of the Sounblaster is it? It is usually stamped on the card>>
PostPosted: Sat Mar 15, 2014 7:26 am
If using an add-in sound card, go into the BIOS and disable features for any on-board audio.. including a MIDI port. Conflicts can arise if not done. Same for a modem, if not used. There are drivers for SB Live! audio cards for Win 7.. but no mention of 64-bit or 32-bit specific. The installer program should detect the OS needs and install accordingly.
Here is a link to all the models in the Sound Blaster/Audigy/Creative products line.
PostPosted: Sat Mar 15, 2014 12:04 pm
I pulled the card and looked all over, but I didn't see anything about a version. These are all the numbers I found on the card ... first there was the sticker on the back with the model number and serial number.
Sound Blaster Live! 5.1 Model:SBO100 S/N: MSBO100140313289 ... FM4 was under the model number in small letters. Here some numbers I don't know what they are ... 0265MN219A ACH ... then a 94V-0. That's all I saw. :-|
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
Win7 Ultimate x64
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
Win7 64
PostPosted: Sat Mar 15, 2014 12:06 pm
I checked the BIOS and the only thing I saw was the audio controller ... nothing else pertaining to sound. The thing is the driver software I am trying to install doesn't see the product. Is a driver needed for the PCI slot? :-|
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
Win7 Ultimate x64
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
Win7 64
PostPosted: Sun Mar 16, 2014 1:41 am
Last OS supported: Windows XP. Change hardware.
 Post subject: Oh no ....
PostPosted: Sun Mar 16, 2014 7:26 am
Where am I going to get a sound card that works with 7 that has a game port? :-|
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
Win7 Ultimate x64
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
Win7 64
 Post subject: Oh my goodness!
PostPosted: Sun Mar 16, 2014 8:05 am
I found that I can get a sound card with a gameport for win7 64 Bit . Well alrighty then!! That's very good news. I will be able to fly FS2004 with most of the 4G of memory. I'm happy. :D
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
Win7 Ultimate x64
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
Win7 64
PostPosted: Sun Mar 16, 2014 8:21 am
No special "driver" needed for a PCI slot.. but the device in the slot may require one. The primary motherboard driver will provide info for all features present, including chipset, device slot, USB and such. While the driver version for XP may be nearly identical to that for Win 7 or 8, certain signatures and parsing may cause non-acceptance to the newer OS versions.
There is an old rule.. if the OS inception date is newer than the device, likely there is an appropriate driver in the OS install library. But if the device is newer than the OS inception date, OEM supplied drivers may be mandated.
Any reason that you don't want to use the on-board sound? Should be nearly as good as what the SB Live! card could produce.. but no game port. You can get USB to MIDI/game port adapters at not much cost. The popularity of a MIDI/game port connection is not as popular today, due to USB enhancements. Yet many sound cards do have them included.. for the digital music device aficionado.
PostPosted: Sun Mar 16, 2014 10:51 am
Download here:
SB Live..
Extract the driver and run it in compatibilty mode for win XP.. Done this before with good results... Your Soundblaster is SB100, one of the really early models. Windows usually sticks driver in for them, but the Gameport is the bane of contention as it is a legacy item (USB taken over)..
