viruses broblem
viruses broblem
Postby betobato » Fri Jul 19, 2013 9:52 am
Hello All,
I believe there is a viruses in my pc, some of the behaviors of the pc is when I reboot the system there is few audio segments start but I can’t find the source of it, the other problems are the pc it freezes, when I am in explorer or fire fox, it does not open few of the programs like Excel outlook. And finally it does not log off.
My operating system is windows 7 pro
I would greatly appreciate any and all help.
Jon
betobato
Postby bdub » Fri Jul 19, 2013 2:01 pm
if you can't dl superantispyware on your machine, dl it on another machine and save it to a thumbdrive, or burn it to a cd.
then put that thumbdrive or cd in your machine and install the program, and run it.
hopefully you can get a scan in then... if not reboot into safemode and see if you can get it to run.
http://www.superantispyware.com/downloa ... PYWAREFREE
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
bdub
Return to General
