MS HAL and changing components
Postby Mac29 » Mon May 27, 2013 3:20 pm
I'm about to change video cards and will be trying to unlock one or more cpu's so I'll be getting another mobo in the near future. As I understand it, MS has a Hardware Abstaction Layer baked into Windows that won't allow you to change parts, it only allows boot to hardware on the list created when OS was installed.
I want to be sure what I'm getting into. I have academic vers of 7 and XP and don't want any bs/jump thru hoops from MS. I don't think the HAL will create problems for a new card but think it will if I change mobos to try and unlock a cpu.
My data is backed up but I'd have to reinstall all appls and other crap. Don't believe you can re-install over the old OS. Anyone have experience in this? Worst case I think I can reinstall everything even if I choose a new build, but I'd rather not have to do so obviously.
Appreciate any input from people who know.
Thanks in advance,
Postby evasive » Mon May 27, 2013 9:50 pm
It always depends on how different the old and the new system are. If you get a different chipset manufacturer of your mass storage controller, please please do a clean install. An "upgrade migration" has too much cr*p in the registry in the long run to be stable in my personal experience. See it as using duct tape, eventually you will have to fix things properly with a clean reinstall.
for XP: ... 57090.aspx
for 7: ... 10%29.aspx
Return to General
