tx pro 2 motherboard
Postby poster1 » Sat May 11, 2013 6:48 am
Hi, I am trying to find out whether the Mitac SPU-75 psu i have, is compatible with tx pro 2 mother board, as when I plug it in, only the mthrbrd /cpu and the disks power on and I don't hear a POST signal?
Would be relieved if anyone could help.
Thanks a lot
poster1
Postby Karlsweldt » Sat May 11, 2013 7:04 am
Welcome to Motherboards.org.
That power supply is way too inadequate for that motherboard! It is rated at only 75 watts, and you would need a minimal 350 watt PSU to power it.
Motherboard specs:
Better to use a 400 watt PSU, it will not "push" more power to the system than required. But the unused wattage is a good factor for proper regulation.
Postby evasive » Sun May 12, 2013 8:54 am
Baby AT power supply, Baby AT board, with this chipset has to be the PC Chips M571
http://m571.com/m571/
Please check the troubleshooting sticky post in the tech support forum.
For this setup if you're not using a supserduper gaming card a 200 or 235 W AT supply will be fine. Make sure the memory you're using is compatible and the jumper settings for the CPU match.
Return to General
