Google Website Issue
Postby c327 » Tue Apr 02, 2013 11:55 pm
This concerns an XP Pro SP3 PC with IE8 installed and using Googles start page.
Yesterday I started getting a notice There is a problem with this website's security certificate.
"The security certificate presented by this website has expired or is not yet valid.
Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
We recommend that you close this web page and do not continue to this website.
Click here to close this web page.
Continue to this website (not recommended)"
The start page works fine along with the IE8 browser, but every time I go to click on GMail or try to sign into my Google account or click on any of the Google or Gmail tabs on the top of the page In get this certificate warning notice.
I checked all my browser security settings and they are all set to default.
The only thing I did recently was to download up-dates to Windows Net Framework. I un installed these up-dates and still have this problem.
Ran Fsecure Black light - Nothing
Ran CCleaner
AVG Root Detector - Nothing
Super Anti Spyware - Nothing
Does this issue have something to do with my PC or is it on Googles end?
Going to uninstall and reinstall IE8 and see what happens.
Any ideas what is wrong here? thanks............
c327
Postby evasive » Wed Apr 03, 2013 12:59 am
Check your system time first! Time to replace the CMOS battery me thinks! Been there, done that.
Postby c327 » Wed Apr 03, 2013 1:19 am
evasive wrote:Check your system time first! Time to replace the CMOS battery me thinks! Been there, done that.
Re installed IE8 no change. This is a Sager Laptop about 4 1/2 years old and has original CMOS battery. Don't know if I can change this battery? I do believe it is a special battery possibly soldered in? Don't know. System time seems OK. Don't have a booting issue with this.
A defective CMOS battery can cause this issue only with the Google Website? All other websites are fine.
This is a model 2096 Sager (Compal I think)
Time to change the battery any way I know. I don't know if this is something I can do if it's soldered in place ????
c327
Postby evasive » Wed Apr 03, 2013 3:23 am
If you are 100% sure your system time is fine then it's not your CMOS battery.
Is that a NP2096? That would translate to JHL90 (aka CL56):
http://en.wikipedia.org/wiki/Sager_Notebook_Computers
for which the service manual is here:
www.elvikom.pl/forum/download/file.php?id=1868
It looks like it has a ML1220 battery in there, it's soldered.
http://www.axamit.pl/33-106-thickbox_de ... nboard.jpg
So before going that route, there's another possibility... If you get that message, in the toolbar of IE there's a possibility to check the actual certificate, can you check the validity date on that one AND where the certification path is leading to?
Postby c327 » Wed Apr 03, 2013 3:51 am
evasive wrote:If you are 100% sure your system time is fine then it's not your CMOS battery.
Yes JHL90
Something happened with this over the last couple of days. Even if I browse to a Google link for Google Chrome or anything else google I get this security certificate warning/notice. Could this website have been hijacked ????
Scan Log:
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 8:21:05 AM, on 3/3/2013
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\PROGRA~1\AVG\AVG2012\avgrsx.exe
C:\Program Files\AVG\AVG2012\avgcsrvx.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Intel\WiFi\bin\S24EvMon.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\SUPERAntiSpyware\SASCORE.EXE
C:\WINDOWS\system32\agrsmsvc.exe
C:\Program Files\AVG\AVG2012\avgwdsvc.exe
C:\Program Files\Intel\WiFi\bin\EvtEng.exe
C:\Program Files\Java\jre7\bin\jqs.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe
C:\Program Files\AVG\AVG2012\avgnsx.exe
C:\Program Files\AVG\AVG2012\avgemcx.exe
C:\Program Files\AVG\AVG2012\AVGIDSAgent.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Apoint2K\Apoint.exe
C:\Program Files\Intel\WiFi\bin\ZCfgSvc.exe
C:\Program Files\Microsoft IntelliPoint\ipoint.exe
C:\Program Files\Common Files\Intel\WirelessCommon\iFrmewrk.exe
C:\Program Files\Apoint2K\ApMsgFwd.exe
C:\WINDOWS\RTHDCPL.EXE
C:\WINDOWS\system32\RUNDLL32.EXE
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb04.exe
C:\Program Files\AVG\AVG2012\avgtray.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Apoint2K\Apntex.exe
C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe
C:\WINDOWS\system32\wbem\unsecapp.exe
C:\WINDOWS\system32\msiexec.exe
C:\Program Files\Trend Micro\HiJackThis\HiJackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: AVG Do Not Track - {31332EEF-CB9F-458F-AFEB-D30E9A66B6BA} - C:\Program Files\AVG\AVG2012\avgdtiex.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG2012\avgssie.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre7\bin\ssv.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre7\bin\jp2ssv.dll
O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint2K\Apoint.exe
O4 - HKLM\..\Run: [IntelZeroConfig] "C:\Program Files\Intel\WiFi\bin\ZCfgSvc.exe"
O4 - HKLM\..\Run: [IntelliPoint] "c:\Program Files\Microsoft IntelliPoint\ipoint.exe"
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [IntelWireless] "C:\Program Files\Common Files\Intel\WirelessCommon\iFrmewrk.exe" /tf Intel Wireless Tray
O4 - HKLM\..\Run: [WorksFUD] C:\Program Files\Microsoft Works\wkfud.exe
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NVMCTRAY.DLL,NvTaskbarInit
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb04.exe
O4 - HKLM\..\Run: [AVG_TRAY] "C:\Program Files\AVG\AVG2012\avgtray.exe"
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [ISUSPM] "C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe" -scheduler
O9 - Extra button: ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra 'Tools' menuitem: ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra button: (no name) - {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra 'Tools' menuitem: ieSpell Options - {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra button: Encarta Encyclopedia - {2FDEF853-0759-11D4-A92E-006097DBED37} - C:\Program Files\Common Files\Microsoft Shared\Reference 2001\A\ERS_ENC.HTM
O9 - Extra 'Tools' menuitem: Encarta Encyclopedia - {2FDEF853-0759-11D4-A92E-006097DBED37} - C:\Program Files\Common Files\Microsoft Shared\Reference 2001\A\ERS_ENC.HTM
O9 - Extra button: Define - {5DA9DE80-097A-11D4-A92E-006097DBED37} - C:\Program Files\Common Files\Microsoft Shared\Reference 2001\A\ERS_DEF.HTM
O9 - Extra 'Tools' menuitem: Define - {5DA9DE80-097A-11D4-A92E-006097DBED37} - C:\Program Files\Common Files\Microsoft Shared\Reference 2001\A\ERS_DEF.HTM
O9 - Extra button: AVG Do Not Track - {68BCFFE1-A2DA-4B40-9068-87ECBFC19D16} - C:\Program Files\AVG\AVG2012\avgdtiex.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (file missing)
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (file missing)
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/windows ... 3734518953
O16 - DPF: {CF84DAC5-A4F5-419E-A0BA-C01FFD71112F} - http://content.systemrequirementslab.co ... 5.11.0.cab
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG2012\avgpp.dll
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: SAS Core Service (!SASCORE) - SUPERAntiSpyware.com - C:\Program Files\SUPERAntiSpyware\SASCORE.EXE
O23 - Service: Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) - Adobe Systems Incorporated - C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
O23 - Service: AVGIDSAgent - AVG Technologies CZ, s.r.o. - C:\Program Files\AVG\AVG2012\AVGIDSAgent.exe
O23 - Service: AVG WatchDog (avgwd) - AVG Technologies CZ, s.r.o. - C:\Program Files\AVG\AVG2012\avgwdsvc.exe
O23 - Service: Intel® PROSet/Wireless Event Log (EvtEng) - Intel(R) Corporation - C:\Program Files\Intel\WiFi\bin\EvtEng.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Update Service (gupdatem) (gupdatem) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Oracle Corporation - C:\Program Files\Java\jre7\bin\jqs.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: Intel® PROSet/Wireless Registry Service (RegSrvc) - Intel(R) Corporation - C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe
O23 - Service: Roxio UPnP Renderer 9 - Sonic Solutions - C:\Program Files\Roxio\Digital Home 9\RoxioUPnPRenderer9.exe
O23 - Service: Roxio Upnp Server 9 - Sonic Solutions - C:\Program Files\Roxio\Digital Home 9\RoxioUpnpService9.exe
O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
O23 - Service: Intel® PROSet/Wireless WiFi Service (S24EventMonitor) - Intel(R) Corporation - C:\Program Files\Intel\WiFi\bin\S24EvMon.exe
O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
End of file - 8673 bytes
c327
Postby evasive » Wed Apr 03, 2013 4:32 am
what does "More Information" give you?
what does a tracert mail.google.com give from the start cmd? Starting to suspect some sort of DNS hijack, the mail.google.com site itself seems to be ok from my end.
Postby c327 » Wed Apr 03, 2013 4:34 am
evasive wrote:what does "More Information" give you?
If you arrived at this page by clicking a link, check the website address in the address bar to be sure that it is the address you were expecting.
When going to a website with an address such as https://example.com, try adding the 'www' to the address, https://www.example.com.
If you choose to ignore this error and continue, do not enter private information into the website.
For more information, see "Certificate Errors" in Internet Explorer Help.
Have been doing a lot of advertising and selling on craigslist (I know say no more). Yesterday the wife opened an email in OE6 pertaining to a reply to one of my ads. it said they were lonely and wanted to hold my hand :) Didn't go over to well with the wife. I deleted it but since then I noticed this browser issue. I was thinking also of some sort of a hijack. So that is why I posted a current log. Could you please take a look at it and see if you notice anything questionable.
Thanks............Mark
c327
Postby evasive » Wed Apr 03, 2013 4:40 am
what does your clock show when you double-click that? If you proceed to the website it should be able to show the actual certificate dates. Your current date needs to be in between those. In my time zone it is currently april 3, 2013 2:40pm
Postby c327 » Wed Apr 03, 2013 4:47 am
evasive wrote:what does your clock show when you double-click that? If you proceed to the website it should be able to show the actual certificate dates. Your current date needs to be in between those. In my time zone it is currently april 3, 2013 2:40pm
You nailed it. It's fixed. The calander showed March not April. :o I remember now.... :idea: Yesterday I was looking at different dates in the calander and was switching back and forth from month to month.
Learn something every day............
Thank you for you help, much appreciated....Mark
c327
Postby evasive » Wed Apr 03, 2013 6:20 am
:o
So not the battery but still a time/date issue. Note to self: have people check their clock first.
Thanks for reporting back it's fixed. 8)
Return to General
