security problem
security problem
Postby betobato » Fri Jan 25, 2013 12:57 pm
Hello All,
few days ago I started seeing this massage box Title: (masage from webpage) and inside the massage box [object error] on my browser and I kept hitting ok but the massage box kept poping back and would not allow me to use the browser and also when I tried to open the Fire fox it would not open!!! can anyone help ???
thank you very much for your help.
Jon
betobato
Postby Mr T » Fri Jan 25, 2013 11:08 pm
More for the virus/malware section, but here goes....
Delete your Cookies and clear your internet cache.
Download and update MalwareBytes Antimalware. You can get it from Filehippo.
Reboot into SAFE MODE (F8 before the windows splash screen, unless its windows 8 ) and run Malwarebytes, just follow instructions.
Once done reboot and run your virus scanner, then update windows fully using Windows Update.
It is also worth downloading and running CCleaner and using its reg fix tool...
Postby Karlsweldt » Sat Jan 26, 2013 9:13 am
Those pop-up warnings are traps! Clicking on the [OK] box or the [X] box may only welcome in those malware hits. Best way is to use the task bar app, right-click and choose 'close'. If the warning box still exists, then reboot the system. If it is still there, then a cleansing is in order, ASAP!!
Set your browser preferences for "no third-party cookies".
Postby Hardware Junkie » Mon Jan 28, 2013 6:43 am
Karlsweldt wrote:Those pop-up warnings are traps! Clicking on the [OK] box or the [X] box may only welcome in those malware hits. Best way is to use the task bar app, right-click and choose 'close'. If the warning box still exists, then reboot the system. If it is still there, then a cleansing is in order, ASAP!!
Or go to the processes tab and find IEXPLORE (if using IE), firefox.exe (if using Firefox) or chrome.exe (For Chrome) and End Task the application.
This method can work better sometimes for really problematic scripts.
Postby rascard2007 » Wed Feb 06, 2013 8:11 am
You can download and install a free utility called spybot search & destroy from www.safer-networking.org and check for any infection
-Wrapped Around Your Fingers-
-The Police-
rascard2007
Return to General
