It is currently Wed Sep 19, 2018 5:00 pm
PostPosted: Wed Sep 26, 2007 7:49 am
Hi, this is my motherboard:
http://www.newegg.com/Product/Product.a ... 6813131143
ASUS M2V-MX AM2
It has 24pin power pin
My PSU, 550 Watt, has only 20 pin, not 20+4pin and plus an extra 4pin for the CPU (right?)
Does it work? What's the consequence/possible damage in the future?
Thank you.
Edit #1:
After searching, it says that it is ok to just plug it in.
http://www.motherboards.org/articles/guides/1487_4.html
I just need a confirmation. Thanks.
PostPosted: Thu Sep 27, 2007 8:41 am
Wrong forum, but yes, 20 pin PSU's usually work .
Pete
PostPosted: Thu Sep 27, 2007 2:29 pm
moved.... 8)
Compaq-Fu Master
PostPosted: Thu Sep 27, 2007 3:14 pm
It also works in reverse, many new cases come with a 24 pin PSU but you can use them on older 20 pin boards.
Pete
PostPosted: Thu Sep 27, 2007 3:39 pm
The extra pins for the ATX power socket are there for a reason.. the 20-pin plug doesn't supply enough current for some mobos. Keep an eye on the plug and socket.. if you note any slight yellowing, then you will need a 24-pin type ATX plug with the PSU. There are adapters which mate to the 20-pin plug and fit the 24-pin socket. Better to have the right power feeding the mobo, rather than having something fail. Yes, a 20-pin plug will work a mobo with a 24-pin socket.. but only if the current demands are not exceeded.
PostPosted: Thu Sep 27, 2007 4:44 pm
Yes, I use a convertor on one of my machines but they can be difficult to come by. I always add an extra 50w on if I'm using a 20 pin on a 24pin board mainly because I bought a job lot of 500w 20 pin PSU's from a company that went bust. :) . I figure 450w should be ample for a basic machine with one HD, one DVD and a couple of other peripherals like a USB mouse and Keyboard. Hmm, there's a power calculator somewhere on the internet that you posted a link for at one time if my memory serves me correctly Karl. Do you still have it?
Pete
PostPosted: Thu Sep 27, 2007 9:54 pm
Yes it'll work fine... The only issue you generally have is when you add a beefy video card like an 8800GTS, or are running two video cards in SLi mode... Other than that there is rarely an issue - reason why - a lot of manufacturers are reducing the power consumption of components for the 'green' mob... This is esp the case in hard drives and CPU's....
PostPosted: Fri Sep 28, 2007 12:36 pm
Pete
http://educations.newegg.com/tool/psucalc/index.html
PostPosted: Fri Sep 28, 2007 12:51 pm
MrCraigCraig wrote:
Pete
WTF! That thing told me I needed 920W :o
PostPosted: Fri Sep 28, 2007 3:55 pm
Yeah, some laughs with that 'power calculator' that NewEgg has.
I was told my Prescott 2.9 Ghz with a gig of DDR and 2 hdd _2 optical drives needed less than 400 watts! Sure!
I believe the "power calculator" that was wanted is called "Kill-A-Watt" from The Fuel Cell Store. It plugs into the line between the device and outlet, providing a direct readout of watts used, voltage, and long-term power use. There may be a 230 volt model available for those areas that do not have 120 volt service. Up to 15 amp capacity. Accurate to within .2%.
